Old 23rd June 2004, 03:42 AM   #1
Tim__x is offline Tim__x  Canada
Question Bridge+Parallel LM3886, Doable?
I want to build a bridged LM3886 based amp for use with 8/4 and yes even 2 ohm loads. I already have a suitable 20-0-20 transformer.
What I'm thinking is a standard configuration with four IC's, two in parallel per a side. Would this be sufficient? Maximum peak current would be slightly under 10 amps an IC, I'm thinking I would use a rather large heatsink with a temp controlled fan.
Would this work? Or should I use three IC's a side?
Old 23rd June 2004, 05:34 AM   #2
Tim,
4 chips will work out fine.
It's better to have loved & lost than to never have had a good pair of speakers at all.......
Old 23rd June 2004, 06:49 AM   #3
Thanks, I had seen that example from the datasheet before, but thank-you anyway.
Really what I'm asking is would it be safe with two ohm loads?
I guess I didn't really make that clear before, sorry 'bout that.
Old 23rd June 2004, 08:56 AM   #4
Electrons are yellow and more is better!
peranders's Avatar
Have you checked Thomas madsen's pcb?
200 watts Gäjnklon (Gainclone) - BPA200
http://www.pbase.com/tlmadsen/das_modul
Have you seen this spreadsheat?
http://www.national.com/appinfo/audi...gn_Guide13.xls
http://www.national.com/appinfo/audi...sign_Guide.pdf
/Per-Anders (my first name) or P-A as my friends call me
Old 23rd June 2004, 10:17 AM   #5
tlmadsen's Avatar
Hi Tim
I think that you are "pushing it" with a 2 ohm load for a bridge/parellel config. Remember that each arm only see ½-load, this means 1 ohm. Since each arm are two chips in parallel they see 2x load, this means that each chip sees 2 ohm !!!!!!!!!!
It does help with the "lower" voltage you have, but I still think it is "pushing it".
Either you can put more chips in each arm OR make a parallel config with your 4 chips (this will "limit" your power in 8 ohm), but make it fly for 2 ohm load.
Have fun
Thomas
Old 23rd June 2004, 10:35 AM   #6
peranders's Avatar
I wonder, do you have two 4 ohms speaker in parallel or four 8 ohms in parallel? Maybe it's better to build two amps
Old 23rd June 2004, 06:32 PM   #7
Thank you all for your help. I knew it would be pushing it, but I wanted to know exactly how much it would be pushing it.
I think I will go for 6 IC's, 3 a side with very hefty heat-sinking.
Bridge Parallel AMP myanmar Chip Amps 15 11th March 2007 10:02 AM
Mass Confusion Over LM3886 Bridge/Parallel Modes and National's Specs.? MartyM Chip Amps 9 1st November 2006 05:13 PM
Bridge or Parallel? Roushon Chip Amps 71 16th September 2006 07:47 PM
Are two separate lm3886 = 2*lm3886 in parallel or bridge mode rs1026 Chip Amps 11 21st October 2004 11:24 AM
Bridge/Parallel LM3886 Amp Toucan Solid State 2 15th March 2003 12:46 PM
Page generated in 0.10516 seconds (66.03% PHP - 33.97% MySQL) with 11 queries
