Old 22nd June 2004, 08:32 PM   #1
Morbid is offline Morbid  Israel
Morbid's Avatar
Send a message via ICQ to Morbid
Question what's CLASS in amps?
sorry for the disknowledge....but I want to learn as much as I can on amps and building since im building these amps i have questions....
whats class A/B/C/D...Z amps? is this the quaility or what?
chipbased is gainclone / transistor is Solidstate?
where can i read good stuff about it?
thanks...,
Chen.
Old 22nd June 2004, 08:45 PM   #2
azira is offline azira  United States
Without trying to start a war....
Class refers to the operating "mode" of, essentially, the output devices in an amplifier.
Some different operating modes examples are:
-constant current flow through the output devices so that they are always "on"
-current flow only through output devices that "need" to be active so that their duty cycles are less than 100%.
-tiered output devices with modulated voltage rails so that at low power levels, less power is wasted.
However, because there are several excellent books by experienced designers as well as textbooks which don't strictly define the differences between classes, there tends to be lots of arguments about what class a particular topology is.
The only thing people can really agree on is if a topology has a constant current flow of atleast 1/2 the peak current you expect through the load, it's most likely a class-A device.
Danny
Old 22nd June 2004, 09:03 PM   #3
leadbelly's Avatar
http://www.diyaudio.com/wiki/index.p...lifier+Classes
Aerodynamics are for people who can't build engines. Enzo Ferrari
Old 22nd June 2004, 09:46 PM   #4
Morbid's Avatar
thanks ! so its like the stk...its only warms if there is signal or output load....
Old 25th June 2004, 02:48 AM   #5
no amp is 100% efficiant. Every amp, even those STK's will put out some heat with no signal. Not much though since it is most likely Class AB operation meaning higher efficiency. If they were class A then they would always be hot even with no signal.
See my website for a (basic) description of classes:
http://www.aloofhosting.com/electronet/audio.htm#class
For Sale: Tube Amps, Class-A Amps, BG Ribbons, Chassis and Other Goodies! opc Swap Meet 23 2nd November 2009 05:04 PM
How about a round-up of Class A kit power amps, or collectable vintage class A? Brisso57 Solid State 4 14th February 2007 10:30 AM
Amps Class G,H,T,Z Gold_xyz Solid State 1 14th December 2005 12:39 AM
Has anyone compared the Chip amps against Class T amps? soongsc Chip Amps 3 24th July 2005 11:50 AM
Page generated in 0.07821 seconds (76.16% PHP - 23.84% MySQL) with 10 queries
