Old 22nd June 2004, 01:00 PM   #1
Default LT338 compared to LM338
I just came across the LT338 on the linear web site. Google doesn't reveal any other references to this product, which Linear claim is an improved version of the LM338. Has anyone here used this chip?
Arnie
Old 22nd June 2004, 01:51 PM   #2
Pedja is offline Pedja  Serbia
No, I did not, but the differences are not that huge. According to the datasheet, LT338 is improved in the way of the tighter voltage reference tolerance, so the output voltage can be more precisely predicted in comparison with the LM338. Not really important in this application IMO, but the datasheet also claims somewhat lower noise of the LT338, and this may (and may not) be more important.
Pedja
Old 22nd June 2004, 02:16 PM   #3
I think I noticed that the output impedence was lower at higher frequencies, which should be beneficial.
Whilst we're looking at this chip, can it be treated in the same way as the LM317 in regards to regulating higher voltages than 32v?
Arnie
Old 22nd June 2004, 03:06 PM   #4
Arnie,
Linear gives only one output impedance graph that refers both to the LT and LM part and, else than the dip at 100Hz, the graph is in agreement with that provided by National. Note that the Linear’s graph which shows the impedance with Cadj=10uF includes the effect of 10uF output cap as well.
If your question is about the safety limit defined by the differential and not by the output voltage, the answer is yes.
Pedja
LM338 Regulated PS Puffin Chip Amps 6 22nd November 2008 05:40 PM
Burning LM338 seftali Chip Amps 15 22nd February 2007 06:21 PM
Cheap LM338's. steenoe Chip Amps 0 8th December 2004 05:39 PM
Capacitor on the adjust pin LM338 ebijma Chip Amps 6 12th October 2004 05:35 PM
about lm338 rulezzz Chip Amps 1 5th January 2004 08:21 AM
Page generated in 0.07453 seconds (71.37% PHP - 28.63% MySQL) with 10 queries
