Old 20th June 2004, 03:00 PM   #1
Rocky is offline Rocky  Norway
Rocky's Avatar
Question Gainclone on +/- 12V PSU
How many watts will I be able to get out of a LM1875 or LM3875 gainclone when powering it with +/- 12V (300VA)?
I am building a speaker system (dipole midbass, horn midhighs) with high sensitivity drivers (97dB/W/m and higher) and need active filters.. 24dB/oct LR..
The plan is to get tube amplifiers (2A3 SET or alike) to drive the speakers in the future, but for now it would be great to have 4 channels of gainclone power built in to the filter, utilizing the filter's +/- 12V PSU... I will not need more than 2W from each clone.. Will the chips be able to deliver this at +/- 12V?
Also, how will the chips heat at such a moderate power? Will I need heatsinks, or can I just bolt them to the alu chassie?
Old 20th June 2004, 03:17 PM   #2
Electrons are yellow and more is better!
peranders's Avatar
http://www.national.com/appinfo/audi...gn_Guide13.xls
http://www.national.com/appinfo/audi...sign_Guide.pdf
Check this file!
You need 2 watts and you plan to use 300 VA transformer?
May I ask what kind of speakers you have and also how high volume you want?
With a "normal" speaker you will get 90-96 dB at 1 m, meaning 80-90 dB in the room. This is not much I would say.
I suggest that you get a 2 x 24-28 VAC/150-300 VA transformer.
According to spreadsheet you will get 5-6 W and with so low power supply voltage you can mount the IC's directly into chassis.
/Per-Anders (my first name) or P-A as my friends call me
Old 20th June 2004, 03:18 PM   #3
joensd is offline joensd  Germany
That will depend on your speaker load.
You can plug yout numbers into this calculation tool.
Yes. For exact figures see above.
If the chassis is thicker than 2mm it most probably will be enough at the power levels you are talking about.
Cheers
Jens
Old 20th June 2004, 03:45 PM   #4
Rocky's Avatar
That is correct.
The Supravox 215 GMF midwoofer is rated 97dB/W/m, the TAD 4001 on the horn is rated around 111dB/W/m but I suspect it's actually louder mounted on my round tractrix horn. Both is 8 ohms steady load.
Out of the question. I'm reluctant even to spend on chips and caps/resistors for the chipamp. My funds goes into tube projects and speakers at the moment, so the chips will have to use my +/- 12V that is already in use in the active filter, or there will be no chips. This is only ment to be a short term solution while awaiting funds for completing my SET tube projects.
Thanks. Thoose watts will keep me running for a long time.
Old 20th June 2004, 03:47 PM   #5
Rocky's Avatar
Freebird + Gainclone = "integrated" gainclone? bikehorn Chip Amps 9 5th January 2006 03:07 PM
JLH v Gainclone? Jezz-the-Fezz Solid State 5 12th December 2005 12:08 PM
Big gainclone steven344 Chip Amps 10 23rd November 2005 07:58 PM
Page generated in 0.09985 seconds (80.64% PHP - 19.36% MySQL) with 10 queries
