SMPS for chip amps
SMPS for chip amps
Old 26th June 2004, 05:02 PM   #11
solaja is offline solaja  Yugoslavia
Default SMPS
Hi Francis
Hier some notes.
Oscilator of UCC3844 run on 200KHz and transistor
IRF810 and ferrite core(Siemens RM10) on 100 KHz.
Switch Mode Power Supply can handle up to 30W power.
I am veri suprised how this power supply influenced
on sound.At this moment i work on revision of circuit and PCB layout.AC voltage will be universal (88VAC-250VAC).At this moment it is for 220VAC.Do you have any expereince with SMPS.
You must take precautions when dealig with.PCB is very critical.
In my preamplifier i have no hume or buzzzzz.
In the preamplifier I have used the tube 6N1P one halfe
per chanel.In anode I have used CCS(10mA) an in
cathode NiCdm battery 1,2V.The coupling condenser
is WIMA MKP-10(1uF/400V).Volume control is
ALPS 100K/log.Signal is coupled with copper solide
core 0.1mm insulated with silk.
Old 26th June 2004, 07:35 PM   #12
Default schematik
Sorry
Old 27th June 2004, 12:58 PM   #13
francis is offline francis  Hong Kong
Thank you, Solaja.
I am not capable of building a SMPS.
I can only build a linear power supply for a tube amp/chips amp.
Is there any place where I can buy one?
francis
Old 30th June 2004, 09:47 PM   #14
Default SMPS
HI Francis
I am sorry for diley.I was busy last few days.I dont know where
you can bay exectly what you need.You probably need +/- 32V
to supplay LM3886.My plan is to make SMPS and power amplifier
with LM3886.It will be this summer.If yuo wish bee pationt meybe
we can make a deal.I am sorry for my English.I hope you understunde me.
Best regards
Old 1st July 2004, 07:17 AM   #15
Hi Solaja,
Your suggestion is great. I would be grateful indeed.
Please let me know when you are ready.
Thanks and best regards,
francis
SMPS for chip ampsHide this!Advertise here!
SMPS for diy audio amps and multi-channel diy amps (and their power supplies) tlparker Solid State 20 12th May 2015 12:23 PM
half bridge smps for chip amp voltage regulation question alexclaire Power Supplies 13 8th March 2008 06:39 PM
New Chip for smps alabpro Power Supplies 5 4th September 2005 04:56 PM
Has anyone compared the Chip amps against Class T amps? soongsc Chip Amps 3 24th July 2005 11:50 AM
