| Chip Amps Amplifiers based on integrated circuits |
I am gathering parts to make a GC around Brian's boards and I am still deciding about the volume control. I am used to making tube amps and usually have 50k or 100k pots. I have also used Alps pots in the past, sometimes using a shunt resistor to raise the sound quality a bit. I might go for a stepped attenuator this time. BTW, anybody tried a transformer based attenuator with a GC? I guess that I would like to start a thread or poll of what type, brand, and value attenuator folks here are using. Tips on locating good attenuators are also greatly appreciated. Michael Percy and GoldPoint are on my short list right now as sources. Thanks for all of the great posts on this board. I have a long list of tips already going into this project... Best, Paul ps. Yes, I did a search but I am hoping for some GC specific opinions based upon personal experience... |
#2 |
Hi
I used an Alps 100k paralleled with 20k resistors. It seems a bit too touchy for me so I'm going to try it without the resistors first and then maybe something like 47k. |
#3 | |
#4 |
If you feel like building one try an Elma 24 position switch with your resistor of choice. If you got the $$$ go for a TKD. Have not heard anything about the cheaper TKD CP2511 pot though. One can also try the DACT CT2 20K Stereo Attenuator. The budget winner IIRC is the Noble. Good luck
It's better to have loved & lost than to never have had a good pair of speakers at all....... |
#5 |
I suggest for sound quality at the best possible price, make a 12 position stepped attenuator as shown here .
As regards a new thread on volume controls, this has really all been covered here before.
The truth need not be veiled, for it veils itself from the eyes of the ignorant. |
#6 |
If you will use pot, go on lowest value which is possible, by Alps is it 10 kOhm. With Elma is possible do it on several kiloohms ( certainly only with semiconductor preamps).
#7 |
Finding rotary switches with 2 poles 12 positions or more is kinda hard though. Mousers has a 2P 24 position switch, but its $50, then you gotta buy resistors (and of course I always buy at least 10 of each resistors at a time
)DS1802's and regulators are free along with some associated hardware and pushbuttons.
I enjoy my organic shapes..... |
#8 | |
I am using a Alps Black Beauty 100k pot with output and ground paralleled with a 15k 1% resistor on my passive preamp. Just put the 15k resistor in last night. It seems to me that the noise level is raised. I'm not too sure about that though, as I just replaced the Noble 50k pot with the Black Beauty. What are your impressions regarding using different resistors with your Alps? |
#9 |
I just removed the 15k 1% resistors this morning.
The noise is lessened. Not too sure if the resistors helped... did not listen to them for an extended duration to find out. (was busy soldering a p2p lm3875) btw, i had my resistors at the rca pins, and not on my pot's pins. |
#10 | |
If your pot is 100K you should use a larger resistor in parallel. Carlos |
| Volume control on DVD player remote. Lose resolution at low volume? | Circlotron | Digital Source | 2 | 10th June 2011 07:20 PM |
| Box Volume is Box Volume, right? | skooter | Car Audio | 5 | 4th November 2008 05:17 AM |
| set volume with 50k Pot on Zen V4 | cHab | Pass Labs | 2 | 17th June 2008 12:49 PM |
| volume pot | william1981 | Solid State | 5 | 25th February 2007 10:31 PM |
| Box volume | eitanwaks | Multi-Way | 7 | 19th April 2005 02:45 AM |
| Page generated in 0.10606 seconds (80.29% PHP - 19.71% MySQL) with 10 queries |
