| Chip Amps Amplifiers based on integrated circuits |
Can I do that? I want to drive a 4-ohm sub speaker with a bridged OPA549. Can they handle 2-ohm loads?
if so, about how much power can be expected from it? if not, can i use an opa541 bridged into 4-ohm? same question, how much power? Thanks, Mike |
#2 | |
Transformer current should be high and heatsink large too. Carlos |
#3 |
I'm using a torrid originally used to power an entiere surround speaker system, so current is not an issue. The transformer puts out dual 44VCT secondaries, and I do not know how much that is after rectifiers.
so are you saying that this chip will work bridged into 4-ohm to get 200W, or that I would get 200W into 4-ohm by paralleling it? |
#4 | ||
22v + 22v should output around 29v after rectification. Should be enough. Quote:
Exact power is not easy to compute on the 549, as many factors are involved. The 200W I mentioned really apply on LM3875/3886 chips. TI does not publish a power curve, so we can only conjecture what you can get. Let's be conservative and say 40 watts at 8 ohms and 60watts for 4 ohm. So I'd say you can expect at least 120W for an 8ohm bridge and perhaps 180W for ohm, paralleling at least two pairs on each bridge. Carlos |
#5 |
Banned
Be careful, the OPA549 only handles 2x30v PSU rails maximum...
#6 |
its not a cheap surround system. its from my broken logitech z-680s.
I was wondering why the thing cranked out so much heat and why it only worked with a 16ohm speaker (two 8ohm in series). if i tried an 8 or 4 ohm speaker, it just made a popping sound on any volume not much above minimum. it ends up that i was getting +/-33V supplies, so I am suprised the smoke didn't escape from the chips. ![]() I put it on a +/-24VDC supply, and I was able to run a 4-ohm speaker perfectly fine, and I even tried connecting an 8ohm and 4-ohm in series and it was still stable. This amp sounds much better and handles lower impedence load than any gainclone I have ever built. My (cheap) onkyo amp goes into protect mode with a 2ohm load, yet this thing doesn't even struggle with it. this is by far the best amp I have ever built. but now, i face a problem. I have no transformer powerful enough for this amp, and 2 amps for the tweeters (two 3886 amps) beside the one from the z680s. The 3886 amps are fine with it, but not this one. How can I reduce the power being supplied to these chips without losing current. I'm thinking of diodes?? Thanks, Mike |
#7 |
I'm thinking a cheap 24V trafo from PE, would be far easier and efficient than all those diodes
I enjoy my organic shapes..... |
#8 |
theres no point buying something when I already have it,
How ineffecient would diodes be? |
#9 | |||
The stability is always related to capacitance drive, which might be a problem with some cables that can have high capacitance. Quote:
But if I were you I would try the 3886 on the sub and the 549 on the tweeters. Carlos |
#10 |
Banned
No...
The OPA549 is good, but the 3886 has better midband and treble, it's really another league. It would be better for the tweeters. |
| OPA549 GC for Car | abid_rehan | Chip Amps | 11 | 13th June 2005 04:09 PM |
| Opa549 | ctardi | Chip Amps | 6 | 8th May 2005 07:43 PM |
| bridged opa549 problems | odysseybmx414 | Chip Amps | 3 | 22nd April 2005 12:09 PM |
| bridged opa549 odd workings | jaudio | Chip Amps | 2 | 18th April 2005 12:29 AM |
| Need help with opa549 e/s pin | punchpeanut | Chip Amps | 7 | 8th August 2003 10:52 PM |
| Page generated in 0.13173 seconds (79.82% PHP - 20.18% MySQL) with 10 queries |
