Old 10th June 2004, 01:42 PM   #1
Default Crossover Humms during use
I built a crossover with the attached schematic. It works perfectly, but there is an audible humm in the speaker. Even with music it is noticable. I have it set up with 0.1uf caps and 15K resistors to get a cutoff frequency of about 100Hz. It cuts off the frequency there, and sounds good otherwise, but I cannot figure out what is causing the humm.
Right now, i'm testing it with a +/-22VDC supply. That would blow the chips so I installed a 7805 and a 7905 regulator on the board. So, the chips get +/-5V. I have checked the voltage and it is fine.
What is causing this? I am using 1/2 of a Phillips MC1458N Op-Amp. I have some sitting around collecting dust, and with the other chip on the board, the LM837 which I originally planned to use didn't fit.
File Type: png alow2nd.png (710 Bytes, 50 views)
Old 10th June 2004, 01:53 PM   #2
markp is offline markp  United States
Maybe it just doesn't know the words!
Actually, it sounds like a grounding problem. Does it hum with nothing connected on the input side and the input shorted to ground?
If it sounds good... it is good!
Old 10th June 2004, 01:58 PM   #3
oh, forgot to mention. only humms loudly when the input is connected. The input is the headphone out of my sterero. When I disconnect it, the humm quiets down.
What I am wondering, is it because I do not have any filtering after the requlators? What if I put a 0.01 uf cap between +5 and gnd and -5 and gnd?
Old 10th June 2004, 02:26 PM   #4
djQUAN is offline djQUAN  Philippines
Send a message via MSN to djQUAN Send a message via Yahoo to djQUAN
using the regulators without output capacitors make them unstable and sometimes oscillate.
your hum may be caused by poor grounding scheme.
I also suggest you use 15 volt regulators to get better headroom for the peaks of the signal.
Old 10th June 2004, 04:08 PM   #5
Try from 10 to 100uF after the regs. Headphone outs are notoriously bad for hum too.
Old 11th June 2004, 01:15 AM   #6
OK, I added a 0.1uf cap on the output of the regulators. The hum is now only heard when you put your ear right next to the speaker.
Its odd since it still shows up just as much on my scope but you can't hear it.
it is a cheap onkyo reciever, so that may also be why.
Old 11th June 2004, 04:06 AM   #7
li_gangyi's Avatar
hmm...sin't +/- 5V a little low?? does the signal clip?? as for the little hum present...how much uF did u put before the regulators??
Kids in the back seat cause accidents...Accidents in the back seat cause kids...
Old 11th June 2004, 12:37 PM   #8
Well, I wanted to use larger chips, but I only had both the positive and negative regulators of the 5V series. I have a +12V, but not a -12V. Well, I do somewhere from when I tore a computer SMPS apart, but can't find it.
It doesn't clip though.
oh, forgot to say, the caps before the regulators are 1000uf per rail in my power supply. I've been meaning to change them for larger values, but when I built it, 1000uf was all I had.
When the amp is all done it is going to have 2 2200uf caps per rail.
Crossover for vifa 2 way setup - how can I find out what this crossover is doing? Tino Multi-Way 11 17th May 2009 04:21 AM
Passive crossover into active crossover hahfran Multi-Way 16 10th February 2008 06:16 PM
Crossover help please :) Tenson Multi-Way 17 15th April 2006 09:34 AM
Can you hear the crossover point of a speaker with a well-designed crossover? 454Casull Multi-Way 11 2nd April 2004 05:48 AM
Page generated in 0.09990 seconds (76.21% PHP - 23.79% MySQL) with 11 queries
