| Chip Amps Amplifiers based on integrated circuits |
I have a transformer that puts out +/- 48 VDC. Should I risk trying it on a parallel gainclone that will have 3 ch. in parallel?
-Paul Hilgeman |
#2 |
+/-40vdc with signal is the datasheet maximum...you are courting trouble if you use these rails...
http://www.electronicslab.ph/forum/i...?topic=32688.0 |
#3 |
To PHilgeman
How big is your transformer (VA) ?? Thomas |
#4 |
Ive run my 8 cahnnel bridged gainclone amp on +/- 42V for a few years now. No problems.
You have to be careful with heatsinking as they get REAL hot. 48V might pushing the limit a little too much. |
#5 |
Maybe you could regulate the voltage down a little. Maybe it's a bit complex for a chip amp tho, I wouldn't really know...
Fave. threads: Marantz CD63 | Philips CD650 | my 3-way dipoles | T-bass for dipoles | EnABL treatment | Arcam Alpha (CD) |
#6 |
Any way to drop the voltage at all?
-Paul Hilgeman |
#7 |
Paul, does your transformer have a center tap?
Jan Didden
/Another new issue: Linear Audio Volume 3! |
#8 |
Banned
Time to regulate.
#9 | |
1) If your transformer is toroidal and you have two secondaries, you can take wire out from both. 2) Regulate to +/-40V, but be careful to heatsink the transistor or regulator quite well, as you should have plenty of heat. The 8v difference should give you plenty of room to regulate in spite of AC line drops. Carlos |
#10 |
Any links to ways to regulate things?
It is a standard transformer, so I cant unwind. It has a ton of VA, guessing from the transformers I have seen, about 800VA or so. BTW, I did run an 3886 for a while on the 52V supplies. It worked find and delivered very tight, deep bass, but then it just locked to the - rail. -Paul Hilgeman |
| Zen V1 Higher Voltage Rails? | fligti91 | Pass Labs | 4 | 13th November 2008 04:00 AM |
| OTL 6c33c Ciufolli v8.2 low voltage rails | danielrs | Tubes / Valves | 3 | 4th December 2005 03:13 PM |
| Need to get the highest voltage swing, which output topology? | EWorkshop1708 | Solid State | 7 | 2nd March 2005 06:56 AM |
| measuring voltage rails | Scribble | Chip Amps | 8 | 20th October 2004 12:03 AM |
| Imbalanced Voltage Rails on Gainclone | Kofi Annan | Solid State | 2 | 2nd March 2004 03:13 PM |
| Page generated in 0.12225 seconds (61.44% PHP - 38.56% MySQL) with 11 queries |
