pcb for 2xSTK4141V
pcb for 2xSTK4141V
Old 8th June 2004, 06:24 PM   #11
metal is offline metal  Jordan
metal's Avatar
Hey Guys
Two days ago, I finished my STK4191V after many years of being lazy. It sounded really good at listening tests, but I am wondering if the transformers I used are enough. I have used two 36 volt @ 5 Amp each,two bridges, and two 6800 uF smoothing capacitors, that gives me (+36 volt @ 5 Amp) and (-36 volt @ 5 Amp). I am driving 8 Ohm speakers, I just want to know if that is enough for this STK.
The PCB was a ready made one, bought it from Mr.Lumanauw from indonesia, the layout looks like the one stated in the datasheets. I had no oscillation problems, so that was a good enough result for me, because when I used veroboard I had notorious oscillations.
Any questions,I am here for you guys
Old 8th June 2004, 06:53 PM   #12
p2mine is offline p2mine  Romania
for my stk4192 i used +-22V rails for testing.
It was clearly not enough, and now I bought a toroid with 2x25V secondary. That means around +-35V no-load.
I think this would be enough.
About your amp, i think that it's enough 2x36V .
Still, stk4191 is rated to Vcc max +-53V. It's about the power you think you need. Personaly, I think that +- 36V is enough for your amplifier.
Old 9th June 2004, 05:30 PM   #13
metal's Avatar
Thank you for the reply p2mine, I was wondering if 5 Amp for each rail is enough at +/- 36 volt.
Thank you in advance
Old 10th June 2004, 01:11 AM   #14
X.G. is offline X.G.  China
X.G.'s Avatar
To p2mine,
My advice correctly is :It will be better that the PCB traces of output GND from the common point of PSU fiter caps are independent.
I can't explain in my poor Engish,sorry.
cheers,
X.G.
Old 10th June 2004, 07:14 AM   #15
Now, can you please draw a scatch for me?
You are saying that for every cap should i have a different trace to the ground? I'm not sure I did understad clearly.
I've drawn a scatch using paint, and now this is the layout(the condensators were replaced only by one larger condensator)
where in this layout should I put the ground for the input?
Thanks for your reply!
Regards!
Old 10th June 2004, 07:19 AM   #16
This is the schetch.. I don't now why they don't display any more the pictures. Probably they don't have enough bandwith any more.....
Old 10th June 2004, 09:08 AM   #17
X.G.'s Avatar
right.
I have no idea of the input GND.I think your origin arrangement is OK.
Old 24th June 2004, 07:32 PM   #18
Default building the PCB
lately, i was busy having school exams....
but, this is wat i've built untill now.
now one of my satelites:
two satelites, staked:
point to point wiring.....
Old 28th June 2004, 12:18 PM   #19
I've finished my amp....
now, i have aproblem. on all 4 channels I have high frequency oscilations...
I've already blew 2 tweeters...
what can be the problem??
i've used the schematics presented in sanyo's pdf..
can the cause be because of the long wires to my soundcard? (tghe wires between my computer and the soundcard are aprox 8 meters long)
should I place some 300pf in parallel with the reaction resistors? would that elimnate the problem??
Old 27th December 2011, 04:27 AM   #20
shravanth is offline shravanth  India
Smile STK
hello
i am shavanth
do you have bottom layout for this STKamp
please share
pcb for 2xSTK4141VHide this!Advertise here!
