Old 6th June 2004, 11:32 AM   #1
Hybrid fourdoor's Avatar
Question Parralleling to run Martin Logans
Im thinking about getting some Martin Logans (maybe Quests or Aerius) which have an impedence range of 2-8ohms. So would it be safe to parrallel two LM3886's so that the ohms to each chip are 4-16ohms? Or maybe 3 LM3875? I'm thinking the woofer will be pretty benign, but its the panels that go hog wild.
I enjoy my organic shapes.....
Old 6th June 2004, 11:47 AM   #2
Also I have some opa541 in a metal can. Think those might be better for this application?
EDIT: Crap I see they don't offer samples of the TO-3 anymore. Only the plastic case. I only have 2 OPA541's. Maybe they will cut me a break since I work there
Old 6th June 2004, 02:51 PM   #3
...wanna buy some extras.....?......
Old 6th June 2004, 02:59 PM   #4
b2fuzzy is offline b2fuzzy  Netherlands
Nice application note how to bridge /parallel
http://www.national.com/an/AN/AN-1192.pdf
Old 6th June 2004, 03:49 PM   #5
Electrons are yellow and more is better!
peranders's Avatar
Default Re: Parralleling to run Martin Logans
Are you really sure about the 2 ohms?
/Per-Anders (my first name) or P-A as my friends call me
Old 7th June 2004, 12:08 AM   #6
towards the upper frequncies ESL's tend to dip pretty low. The Martin Logan website lists some of the new models as dipping to 1 ohm.
I just want to make sure they won't explode or anything
Old 7th June 2004, 10:20 AM   #7
Faber is offline Faber  Italy
Send a message via ICQ to Faber Send a message via MSN to Faber
I've driven the Aerius I with a bridged (not paralleled) GC amp with a lm3886.
You will need to use a good heatsink, but it doesn't explode and works very well. The definitive design is using the 4780 in the same config.
It's about 6 months that those amps are working
Bye!
Fabrizio
Old 7th June 2004, 10:30 AM   #8
peranders's Avatar
I think you can be quite calm because you won't put out max power at 20 kHz. I think you should look intstead of the current demand for your type of usage.
You can get out up to 11.5 A in short term which may be sufficient for you needs.
BTW: I have ML SL3 and I'm quite fond of the electrostatic sound, no party animals exactly but still does a good job.
Old 7th June 2004, 10:37 AM   #9
peranders's Avatar
As you know I have ML and I can tell you that 50-60 W is just on the edge if we talk power because of the speaker's rather low efficiency. This will not create rather high sound level but you are very near clipping (=bad sound). 150-300 watts is more appropiate I think. Maybe you should look at Thomas Madsens, "Das Modul"?
parralleling aleph 30's audionut Pass Labs 5 29th January 2009 09:50 AM
Pass Amps for Martin Logans Sandor Pass Labs 3 7th March 2007 10:34 PM
Aleph 1.2 and a pair of Martin Logans oblerum Pass Labs 14 21st February 2005 12:42 AM
Parralleling Rectifiers and Voltage Regulators Hybrid fourdoor Parts 11 27th December 2003 12:12 PM
parralleling aleph 3 channels audionut Pass Labs 0 28th October 2002 12:44 AM
Page generated in 0.12356 seconds (73.35% PHP - 26.65% MySQL) with 10 queries
