| Chip Amps Amplifiers based on integrated circuits |
#111 |
Carlos
Why do you use ceramics for this purpose? Just because the datasheet mentions ceramics? O.K., they are small. But don't you think, good film caps are better for this application? Franz |
#112 | ||
diyAudio Moderator Emeritus
I just sent you a reply about this, and am willing to provide help if you need it. I forgot to mention that Advanced Circuits also has a cheap prototyping service, www.33each.com , where you can get a single 85sq in board made for $33 (min order 3, and lot fee of $50 charged for multiple designs on a single pcb). I used their service for my cdpro2 project: http://www.briangt.com/gallery/cdpro2-pcb2/uncut_pcbs The boards are 1 oz copper, but are otherwise fully featured, and you can fit quite a few boards on the 85 sq in. It comes out to $150 shipped for 3 - 85 sq in boards with as many designs as you can fit on them. As for checking interest in a possible order, a Wiki might be good for this. As for the boards, I would recommend packaging all the boards together on a single pcb with scoring, much like the LM3875 boards I put together. This should lower the costs a lot, and make shipping much easier, having only a single pcb. Here is the reply that I sent to Troy, if anyone else wants the board information I sent him: Quote:
One more thing: for ordering pcbs, there is no real cost difference between single and double sided pcbs, so you shouldn't constrain the designs to a single layer, if the routing would be more optimal on 2 layers. Just a suggestion. -- Brian |
#113 | |
Banned
You can use films of course. But they are bigger, and then the electrolythics won't be as near as they shoud. These op-amps like capacitance near them. Ceramics bypass to higher frequencies than film caps, but the main point here is to have all the caps as near as possible to the op-amp's PSU pins. Yes, you can throw away the good sound of the OPA627 by not doing this. With veroboard I put ceramics inside the socket OPAs will reward you with fantastic sound if you know how do deal with them. Other op-amps (like AD) work fine with "normal" layouts seen on most commercial products. But they also like to be well treated.
#114 |
I haven't built my four LM3875-based Gainclones yet, but if these boards will work with that chip and the price is right, I'll need four sets of PCBs.
Regards to all, Scott |
#115 |
Carlos: thanks for the tips.
Expect another version soon.I'm trying to allow for close coupling of the bypass caps at/near the chip pins while providing for a more "convenient" spot for the more "lazy" folks. On the amp boards I just allowed for placement without "room" on the top (underside would work - in fact, I think I can place the holes closer in that case! glad you said something. More tweaks.) - I will do this for the bypass caps on the buffer too. As to moving the other caps near the chip, see above - I'm working on it. It makes perfect sense to me now, so that must be a tidbit I picked up without quite ever grasping it fully. ![]() My goal is to etch this stuff myself for trials, make any modifications if needed, then release printable artwork as well as contribute to any group buy effort that may happen. I would want to make sure that the contributors are credited properly (Pedja and Carlos in particular for their schematics, me for the artwork) and a few other things relating to any group-buy effort as well. I think blue PCBs would be pretty slick. Or black. . . Brian: I had gone the double-sided route at one point and the request was made to go single so people could etch these themselves. I would definitely clean some things up by going double sided if a group-buy does go forward. C |
#116 |
C, you are doing excellent work. Have I ever mentioned that, my sister lives in the Windy City too? My nephew too (the best kid in this world...). My sister’s husband works for the firm named Windy City.
I was pretty busy these days, but will look at the layout (which seems quite nice at the first sight) later today. Pedja |
#117 |
Ok, looked at it a bit… it still looks nice though I have a few thoughts.
The C3 on the regulator board, if used (if there is need), is good to be close to the regulator but as long as we consider it as an optional component I would give higher priority to R1. Incoming and outgoing traces around the reg itself are narrowing, I guess that is just an oversight. The JFET buffer board is good and it would probably work well, only gate and source resistors on J310 are swapped. The resistor 1M may be put in raw with (below) these J310’s resistors and 1uF cap may be dragged down, the cascode will became tighter. You can also escape certain wiggle between 2SK170 and J310 if you rotate J310 for 180 degrees. Do I understand well the amps themselves, inverting amp do has an input cap but non-inverting does not? Pedja |
#118 |
Here we go again.
Bypass caps are not on-board at all, though holes are provided if you choose to mount under the board, or you can mount straight to the pins or whatnot. The 1M resistor is rear-mounted. There's room to slide it over and mount above the two resistors if that would be preferable.![]() ![]() ![]() One thing I'm not quite clear on: Pedja said: "Incoming and outgoing traces around the reg itself are narrowing" - if this refers to the traces getting narrow to clear the other reg pins, a question: Is it better to have smaller traces that are consistent in size vs. thicker and narrow right at the reg? My understanding was the latter gave most of the capacity of the thicker traces while still reaching the pins. I can certainly narrow those traces so they're the same size the whole way. C |
#119 |
Hey C-
What program are you using to draw these circuits? Also can you send me the files when they are complete? Then I can get quotes on having them made so we have an idea on a GB price. I will Thanks in advance, Troy |
#120 | |
Sheldon |
| Power supply for FIRST WATT B1 BUFFER | ANADIGIT | Swap Meet | 25 | 22nd May 2009 03:39 PM |
| Power Supply Regulator for T-Amps | DreadPirate | Digital Source | 0 | 31st December 2007 03:00 PM |
| ucd400: Hypex HXR12 Regulators vs. Input buffer auxiliary supply | jdec | Class D | 1 | 23rd December 2007 06:52 AM |
| Page generated in 0.16772 seconds (77.04% PHP - 22.96% MySQL) with 11 queries |
