| Chip Amps Amplifiers based on integrated circuits |
A few hours ago as I was reading a bit on the net, I stumbled across a page concerning input protection for ICs like opamps and the likes. Here is the image that was included on the webpage: ![]() Now, my basic understanding tells me that if the input is either higher than (Vcc + diode drop) or lower than (Gnd - diode drop) that amount of voltage will go to Vcc/Gnd. So far, no problems (I hope ). However, in the SSM2404 datasheet, there's another type of input protection shown. Here's a screenshot of it: I'm guessing this works as follows: if the input's higher/lower than (diode drop) the 'amount of voltage' exceeding that (diode drop) gets shorted to ground. If that's correct, that means that no input signal greater than +- 0.7v is possible (well, unless you start putting diodes in series of course). Two anti-parallel diodes let all voltage about their voltage drop pass, right? Is that correct? If it is, wouldn't that be a mistake in the SSM2404 datasheet? I can't imagine someone's willing to implement such a sort of "protection", since it will ruin just about every audio signal you put at the input. Am I correct? I suppose not, so could someone please explain it to me ?
Website: http://members.lycos.nl/anthonyvh |
#2 |
I notice that I've never seen such a protection in any amp schematic I've looked at. This seems to me a pretty good indicator that you're right...
#3 |
Well, I'm going to use it for a preamp, using it for an amp would be kind of silly, because to get the protection to work, you'd need an input voltage almost equal to the amp's working voltage. If the amp would then try to amplify the signal, it would of course fail & start clipping, because there wouldn't be a high enough voltage available.
Anyway, I'm still in doubt about the lowest circuit. Should't it be: input - diode - +V & -V - diode - input? Why are they using the ground as the 'reference' voltage, to which the input voltage is passively compared?
#4 |
In the second case (parallel diodes) the voltage across the diodes is essentially zero: they are on the inverting input, the virtual ground. They are just there to limit the input in case of problems, but will never see any appreciable voltage in practise. Jan Didden
/Another new issue: Linear Audio Volume 3! |
#5 | |
The series resistor you're talking about is R1 (the 100K/M10) resistor, right? The 10K hasn't got anything to do with it and is just there to keep the input of that NAND gate high, right? Now, the 2nd circuit. The signal is at virtual ground, so no signal would ever reach a high/low enough voltage, right? Could you give an example in which case those diodes might be usefull?
#6 |
Arise you dead thread.... You gotta love the search function!!Ok, so I am researching this particular solution for limiting the input voltage / signal into a chip amp I made for a simple paging amp driven system... I want to remove the volume control from the front of the amp and have only the mic volume to adjust. So when it is distorted there is only ONE knob to adjust... So the first drawing would suffice to limit the input voltage to +/- .7 volts max? Anything over is "drained" to ground?
Troy Thinking positive doesn't make things better, it makes you a better person. |
| Input protection diodes: More harm than good? | MJL21193 | Solid State | 16 | 20th November 2008 02:49 AM |
| Class D input LM311 Inverting input | zox2003 | Class D | 1 | 1st February 2008 07:48 AM |
| speaker protection (OR) overload protection | myanmar | Solid State | 7 | 13th July 2006 08:21 AM |
| Protection of Mosfet Amps from input Overdrive... | Workhorse | Solid State | 21 | 22nd June 2005 03:57 PM |
| current bias j-fet input 2sk170 ,2sj74 at input stage | YUTK | Solid State | 11 | 2nd June 2005 03:34 AM |
| Page generated in 0.10548 seconds (80.42% PHP - 19.58% MySQL) with 10 queries |
