| Chip Amps Amplifiers based on integrated circuits |
Here is my stereo gc case that I am working on. Heatsinks are Conrad mf25-75 . I got the aluminum from a local place called Blue Collar Supply in Sacramento for a really good price. Thank you George!
Before drilling ![]() Clamped the 1/4" plate for drilling ![]() Drilled the front holes ![]() Countersink ![]() This is the front view of 1/4" plate attached to 1/2" square ![]() View of the back plate with rca holes ![]() Overall view w/o heatsinks and top plate attached . ![]() Clamping 1/2" squares for drilling into heatsinks ![]() Today I started drilling and tapping heatsinks This is the bottom with stand offs to hold the boards in place Like so So far, everything lines up fine now I need to fit the bottom cover ![]() ![]() ![]() I got some cleaning to do now
left lane is for passing, slower traffic keep right please. |
#2 |
Very nice!. simple but impressive result. I have been thinking of doing something similar for mine
#4 |
Stack everything double, both GC and rectifier boards, and make a 4-channel GC. Right on top of eachother.
That case is capable as well as nice.
UrSv Those who say it can't be done should not stop those who are doing it. |
#5 |
Nice looking work. Those heatsinks are going to be overkill for just 2 channels, I second the idea of making it 4 channel.
Great to see another person from Sacramento. Thanks for the info on the metal shop, I'll have to check it out for some of my own cases. -- Danny |
#6 |
Banned
Thats impressive : O) I like that..
#7 |
Don't think there's enough height to double.
#8 |
Hello,
I did think about doing that, maybe in bridged mode ? I don't believe I can fit multiple toroids in there
#9 |
I got the final needed components from Brian and populated the boards. I used Panasonic capacitors on the psu and amplifier boards, saved the BlackGate 4.7s for later use.
![]() Power supply works fine, 36 volts on each side . Now I just need to mount the chips to the heatsinks. I had small problem on one side, after I made a 6-32 tap i tested it with aluminum bolt and broke it I managed to drill it out with a very fine drill bit right in the center, then used a hole punch that I stuck inside the broken bolt that was stuck in the heatsink thread and removed it
#10 |
diyAudio Editor
Very nice work. What is the VA of the transformer?
Blue Collar Supply had Aleph heatsinks a couple of years ago.. I guess I should drive over just to visit them!! |
| The DIY gainclone chassis thread. | Spasticteapot | Chip Amps | 21 | 13th March 2006 02:36 PM |
| GainClone FAQs thread? | troystg | Chip Amps | 7 | 18th October 2004 01:56 PM |
| Gainclone building thread based on BrianGT's boards | meat | Chip Amps | 752 | 8th August 2004 06:25 AM |
| Page generated in 0.11226 seconds (82.44% PHP - 17.56% MySQL) with 10 queries |
