| Chip Amps Amplifiers based on integrated circuits |
Now that I have sorted out the transformer and the potentiometer, I need to take a look at the chassis. I have found something interesting here. I know they are not that big but since I intend to build monoblock amps, they should work OK. Has anybody seen something like this in Canada or in the US ? I have tried searching their parent offices in North America without success.
#2 |
Looks like the cases Parts Express sells...
#3 |
yeah...try hammond cases. they have a type that's nearly identical in a plethora of sizes. They're cheap and good looking. Available from digikey (I love digikey, best prices and quick delivery, also excelent shipping)...here are the links:
Hammond http://www.hammondmfg.com/1455.htm Digikey Canada (search for 1455), http://dkc1.digikey.com/ca/digihome.html
Fighting the program since 1976. |
#4 |
should work. thay allso make good headphone amps
#5 |
The larger from Hammond on their #1455 series looks quite good, but the height is a bit low for clearing a toroid transformer.
Height is 51.5mm, when my 300VA from Toroid would need at least six. Perhaps other toroid sizes are shallower. Carlos |
#6 |
or you could make a power humpty on the side
#7 |
Hi, what is the RS # you are referring to ?
#8 | |
Parts Express sells this case that is 2.36" high. The toroid I'm going to use is 1.5" tall so that shouldn't be so bad. I'm also looking around town to see if I could find a few metal shops that could provide the sheet metal I'd need to build them myself. But first thing first. I've got to order Brian's kit first as well as the toroids from ApexJr and build them. Then we'll see about the case. |
| Aluminium vs steel chassis | Rob11966 | Tubes / Valves | 86 | 22nd January 2009 04:45 PM |
| Source for Extruded Heat Sinks - longer lengths | Dr. Most | Parts | 4 | 23rd June 2008 04:51 AM |
| MANY & BIG & NEW High-power black anodized extruded aluminium HEATSINKS for sale | cocolino | Swap Meet | 18 | 5th December 2006 07:39 AM |
| extruded aluminum boxes | space-cake | Parts | 3 | 3rd October 2006 05:44 PM |
| Aluminium chassis finishing | FrankDIY | Everything Else | 0 | 21st August 2002 11:35 AM |
| Page generated in 0.10416 seconds (69.71% PHP - 30.29% MySQL) with 11 queries |
