Old 30th May 2004, 09:42 PM   #1
xplod1236's Avatar
Send a message via AIM to xplod1236
Default high-voltage chip amp
is there a high-voltage chip amp? I'm looking for something that will run off +/- 50-75v rails. I'm not worried about current handling, because I can always parallel the chips.
Old 30th May 2004, 09:48 PM   #2
Banned
http://focus.ti.com/docs/prod/folders/print/opa445.html
but you would need to parallel 100 of them or so - better to make a current gain stage with transistors behind it. (see datasheet)
Old 30th May 2004, 09:59 PM   #3
paulb is offline paulb  Canada
You'll find something here:
http://eportal.apexmicrotech.com/mainsite/index.asp
Old 31st May 2004, 02:22 AM   #4
well when i bought a set of logitech z-680 speakers, the first one had an annoying rattling sound so i had them send me a new set. so, the first thing i did was tear apart the old one. the amps inside it, according to the datasheet can run off of 120V (+/-60V) supplies, and also produce 100W at that voltage (i think)
i also forgot what chip it is.
Old 31st May 2004, 01:32 PM   #5
djk is offline djk
djk's Avatar
The power supply is in the subwoofer and each of the sats is powered by 53W RMS
Old 31st May 2004, 01:44 PM   #6
yes, the trafo is 26.2-0-26.2V. There is also a 14V single output. . I am not sure what voltage it is after the voltage boost from the rectifiers.
I know that the chips aren't running at full power, since there is no way its getting +/-60V
But that is still pretty high voltage.
Old 1st June 2004, 11:15 PM   #7
The Z680 uses TDA7294 amp IC's. Absolute maximum rating for this chip is up to +/- 50V according to the data sheet, but it's much happier below 40V. Keep in mind this is also assuming single-ended into 8 ohms. If you want to use a standard 2-chip BTL config you should not exceed 35V into no less than 8 ohms (basically same constraints as LM series).
I have a Z680 and it has 8 ohm sats in SE config, subwoofer is 8 ohm BTL config. The voltages listed above from the data sheet are consistent with a 26.2-0-26.2 VAC transformer since this would essentially yield ~35VDC unloaded. 35V into 8 ohms according to the IC data sheet yields 70W typical. My Z680 spec says 62W into 8 ohm sats, 188W into 8 ohm BTL sub, so these ratings make sense given the transformer and the IC specs.
The 14V winding on the transformer is sent to the digital control pod and is used to create the low voltage DC for the digital circuits.
Cheers
Old 2nd June 2004, 03:09 AM   #8
yes, i didn't know that, all i knew was that when i looked up the datasheet it said it was +/-50
High voltage, high current super regulator, possible group buy peranders Group Buys 54 2nd June 2009 09:43 AM
Wanted - High Power, High Voltage, Audio Frequency Transformer Manual. kimbal Tubes / Valves 4 11th May 2009 08:05 PM
high frequency high voltage power supply... moray james Planars & Exotics 6 23rd July 2008 07:57 PM
6BY5 High Voltage & High Current Choke Input Design P.S. snoopyma Tubes / Valves 7 28th June 2006 01:32 PM
Page generated in 0.09240 seconds (77.68% PHP - 22.32% MySQL) with 10 queries
