Old 28th May 2004, 03:28 AM   #1
palesha is offline palesha  India
Default Gainclone in parallel mode
I wish to make one gainclone mono 100W amp @4ohms with LM 3886 without volume control. I will like to know the people who hv done this or hv done similar project.
Old 28th May 2004, 04:03 AM   #2
tool49 is offline tool49  Canada
tool49's Avatar
200 watts Gäjnklon (Gainclone) - BPA200
Old 28th May 2004, 04:21 AM   #3
Is this about parallel gainclone?
Old 28th May 2004, 07:11 AM   #4
Electrons are yellow and more is better!
peranders's Avatar
Paralleling is required if you also bridge connect _or_ have load under 4 ohms.
Check these files:
http://www.national.com/an/AN/AN-1192.pdf
http://www.national.com/appinfo/audi...gn_Guide13.xls
http://www.national.com/appinfo/audi...sign_Guide.pdf
To answer your question: Thomas Madsen's "Das Modul" is a developed version of BPA200 taken from AN-1192
/Per-Anders (my first name) or P-A as my friends call me
Old 28th May 2004, 09:17 AM   #5
tlmadsen's Avatar
Default parallel chips
Hi Palesha
Have a look at my replay in:
Can you tell me how to beef up PA100?
It is all about parallering
Have fun
Thomas
Old 28th May 2004, 11:27 AM   #6
Default Re: parallel chips
If you look at one of Jeff Rowland's amps (the photo is on another HD), he implements a multi-turn pot. It probably zeroes the DC offset on each chip, as he parallels 3 LM3886s on each bridging side.
The Concentra, on the other side, doesn't seem to have individual adjustment and apparently uses inverting LM3886 arrangements.
Carlos
Old 28th May 2004, 11:29 AM   #7
The Concentra amp modules:
PCM1792 in parallel mode babaudio Digital Source 0 12th July 2005 10:26 AM
Difference between Bridge & Parallel mode john_lenfr Chip Amps 13 4th July 2005 01:27 PM
Parallel gainclone questions ejn327 Chip Amps 6 6th January 2005 05:28 PM
Another parallel gainclone (Pics) Jye Chip Amps 2 2nd November 2004 11:10 PM
Inverted gainclone with noninverted bridge mode akunec Chip Amps 0 20th October 2004 12:30 AM
Page generated in 0.07840 seconds (76.41% PHP - 23.59% MySQL) with 11 queries
