| Chip Amps Amplifiers based on integrated circuits |
I built an LM3886 based amp for my house and loved it, so I wanted to do the same for the car. So here's my "car clone" the donor amp was a Crossfire tek 35.4 (not exactly good sounding, and mine was broken) voltage rails are +/-28 to 29v depending on battery voltage, and the amp was capable of around 220-280w rms total so it should do nicely with 4 LM3886 @ 4 ohms..
#2 |
And the inside...
#3 |
I wouldn't mind doing something like this myself, except with some P3A's.
Let us know how it turns out. |
#4 |
last one..
#5 |
I think u hv used parallel gainclone. It looks stereo. Can u give details ( schematics) how u hv done it without volume control.
Why u hv not used the pcb for 3886? This will help to do the same. |
#6 |
jjdche, I'd go for it.. I got lucky and the power supply ends and the amp begins all in a pretty clear line, so the cut was easy.. I'm sure other amps wouldn't be so easy.
palesha, it's actually 4 individual channels (to run front and rear speakers in a car) the schematic is one I found on this site (inverting gainclone) and works very well, it's actually for an lm3875 but I just used the "mute" circuit from the national data sheet. there's no volume control because my car cd player has one so it's not needed. I didn't use pcb because I'm just playing around, when I find the schematic I like best (tried 3 now, deciding between 2 of them) I might go with pcb's later on. if you have anymore questions (or suggestions) don't hesitate to ask (advise) I'm still learning, but it's nice this is a fun and fairly inexpensive hobby to do so.. |
#7 |
I actually have a 4 channel amp that had one of the channels crap out. I haven't really looked inside it recently but its a good donor amp. Hopefully the power supply will be easy to isolate.
#8 |
Hey rwaudio I know this is a real old post and if you ever see this reply post I would like to talk to you about the amp and how you cut the board in half for the power supply to use. I have never in my life seen something like that ever done and especialy work.
Two BIG thumbs up brother. But please I need to talk to you about this so I hope you get this. I'm a new member so I can't e-mail you until I do some more posting. Contact me thru this site or I'd rather you e-mail me. Great job! |
| FS: LM3886 Gain Clone Chips (19) | bolserst | Swap Meet | 5 | 26th October 2008 06:35 PM |
| second clone | Leonidas | Chip Amps | 5 | 26th March 2006 12:07 PM |
| Are two separate lm3886 = 2*lm3886 in parallel or bridge mode | rs1026 | Chip Amps | 11 | 21st October 2004 10:24 AM |
| LM3886 gain clone vs STK4048XI for 4 ohm load | filgor | Chip Amps | 0 | 25th September 2004 12:05 PM |
| Question regarding ProAc 2.5 Clone and Tempo 2 Clone | zoooh | Multi-Way | 5 | 11th March 2003 08:19 PM |
| Page generated in 0.08986 seconds (72.73% PHP - 27.27% MySQL) with 11 queries |
