Old 21st May 2004, 07:43 PM   #1
Vikash is offline Vikash  United Kingdom
diyAudio Moderator Emeritus
Vikash's Avatar
Default Newbie GC complete
...you guys must be fed up seeing that title.
This is was one hell of a buzz. I can't believe I built an amplifier. yay to me .
I used old parts where possible, so this one channel has cost < £10. I followed the NS schematic more or less. It's an absolute mess but it works fine. There is the slightest hum that can be heard only when my ear is put right near the woofer, but I'm hoping that will go once I sort all the wiring up and fix everything in place. I recall measuring the DC offset to < 4mV which looks too good to be correct?
I was somewhere between pessimistic and realistic in my expectations, and although I won't claim some superioior GC sound (well those caps must be 15 years old to begin with) I must say I am impressed.
I've heard a few tracks, and I feel there is an ever so slight lack of bass (but then again I'm listening on a pair of JBL control 1's at the moment) but the midrange already seems to outdo my midfi mini system. I could hear digitization effects in one (poorly compressed) mp3 track which I'd never picked up on before, and I made out some new sounds in another that I'd never really noticed before. The last time I experienced this was when hearing a pair of Logan ESL's for the first time.
Cheers to Nuuk in particular. Your site is a GC newbie's best friend
"The human mind is so constituted that it colours with its own previous conceptions any new notion that presents itself for acceptance." - J. Wilhelm. (But I still think mine sounds better than yours.)
Old 21st May 2004, 08:40 PM   #2
ekd is offline ekd  United States
ekd's Avatar
Default Be careful!
This can become the most dangerous type of addiction... An affordable one.
Ditto. Nuuk's site was my diving board as well...
E
Old 21st May 2004, 10:10 PM   #3
Ropie is offline Ropie  United Kingdom
Ropie's Avatar
I fell into the dungeon last year and I'm still looking for the way out
Old 21st May 2004, 10:46 PM   #4
ekd's Avatar
Default I got bad news...
The guy hanging on the wall over there says there is no way out...
E
Old 22nd May 2004, 08:10 AM   #5
Nuuk is offline Nuuk  United Kingdom
Nuuk's Avatar
Tee hee - there is no escape from the Decibel Dungeon!
Well done Vikash and welcome to the club.
May I suggest replacing those old caps when you can as they are probably more important in the GC design than some other amps where there is more capacitance.
And thanks for all your kind comments on DD. I hope to be adding some new stuff on GCing very soon now.
The truth need not be veiled, for it veils itself from the eyes of the ignorant.
Old 22nd May 2004, 01:21 PM   #6
mAJORD is offline mAJORD  Australia
congrats.
im still trying to be convinced that my GC could be as good as a more expensive discrete design. even tho it sounds great.
It dosn't fit with me
Old 22nd May 2004, 02:34 PM   #7
Vikash's Avatar
At present, the caps are 5600uF. I've seen small value caps placed close to the pins of V+ and V- (in addition to the smoothing caps). What is the purpose of this? Are they used when the PSU caps are far away?
Also, I found a difference when putting a 22uF cap close to pin 8 (and the resistor afterward). What is the name of function of this cap (I know it's not a smothing or snubber cap etc.)?
Lastly, I haven't the faintest idea what the resistors I've used are rated at. Is there a minimum requirement for any of them?
Nuuk, I have a few suggestions about your GC FAQ which you may want to take on board. Perhaps I will email you a list of the things that wern't obvious to me which may help others too...
Old 22nd May 2004, 03:19 PM   #8
Nuuk's Avatar
The 1000 uF caps are generally recommended because that level of capacticance has been found to give the best sound by most GC builders.
Some argue for more but it is felt that higher values 'slow' down the sound or affect the tonal balance.
Except for the 0.22 R on the output (if you use one), the other resistors can be 0.125 watts. I suggest a minimum of 3 watts for the 0.22R.
Yes, please contact me (use the form on DD) with any suggestions for the FAQ page.
Old 22nd May 2004, 04:16 PM   #9
pinkmouse's Avatar
Nice subtle spin there, Nuuk, ever thought of going for Alistair Cambell's old job?
Al
I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort
Old 22nd May 2004, 05:17 PM   #10
Rarkov is offline Rarkov  England
Rarkov's Avatar
Send a message via ICQ to Rarkov Send a message via Skype™ to Rarkov
I'll let you know about the capacitance when my GC4s are complete.
GC1 & 2 - 5600uF on a seperate supply followed by 1000uF at the rails. This was to reduce the indution of 50Hz by the umbilical cords.
GC3 - 1000uF at rails only (Tube buffered)
GC4 - 10000uF at PSU + 1000uF at rails. Same chassis.
I have tended to find that the extra capacitance on the PSU and th compulsary 1000uF at rails sounds best. Not "slow" or adversly affected in the least. I am yet to listen to my nearly completed GC4s so I can't comment when the PSU is in the same chassis. See my website for details. I should note that all of these designs are monoblocks.
Gaz
Simple amp for a complete newbie Shardik Solid State 4 4th July 2008 12:53 AM
Power amp kit for a complete newbie FlorianO Tubes / Valves 6 21st August 2006 01:38 AM
Newbie 7 channel Gainclone complete sachi Chip Amps 15 26th February 2006 08:31 AM
Complete newbie lpoht Solid State 5 6th December 2001 08:30 PM
Page generated in 0.11768 seconds (75.01% PHP - 24.99% MySQL) with 11 queries
