| Chip Amps Amplifiers based on integrated circuits |
Has anyone ever implemented a circuit to turn on an Amp when you get a 12 volt signal from a reciever/processor?
I'm thinking of having a tri-state switch that has an "On" state which ignores the 12 volt signal, an "Off" state to turn off power completely and a "Standby" state that would switch the amp on when the 12 volt signal is detected. Here's a conceptual drawing to help explain. I don't know how to draw a proper circuit diagram, this is just a high level idea.... |
#3 |
i was hoping for something already purpose built. i don't know too much about circuits, so i'm not sure that i could modify that plan...
#4 |
The switch Drawing has a big problem.
All of the outputs are tied together.
John DeRosa {Hotwaterwizard} |
#5 |
I've built a very simple circuit that has worked without a problem for 8 months now. I got a 12V DC 1 amp wall wart and plugged it into the switched AC outlet of my receiver. I used this 12V output to control a 12 V relay with a 30A (@>120 AC Volts) contacts. I use the relay contacts to switch the AC to several components, among them a 1200 Watt Crown Pro Amp. I bought the wall wart and relay from All Electronics for less than $10.
#6 |
This is how I plan to do it: in every amp/active crossover/whatever I create, I will put this circuit:
If the amp/... has a power button, it will be connected to one of the enable inputs. On the back I'll have 2 trigger connectors (probably a serial connector), one input and one output. The output pins are directly connected to the pins on the input connector. The triggers (8 of them, 1 ground => serial connector) will be controlled by a relay driver in my preamp. The driver is capable of sourcing 200mA per trigger line. In the amp/... one of the input pins is connected to one of the enable pins of the above circuit. If you have more than 8 things you want to remotely control, you can always use logic gates etc. to have more possible "control codes". The only drawback I see to this is that you need an appropriate voltage in the amp/.... If you don't want to use the device's power supply for this, you'll have to add a small separate supply. A 78xx & a small transformer is pretty small, so that shouldn't be too much of a problem. *Oh btw, if you want tri state with this circuit simple put a 240V switch in series with the AC input. You can then mount it on the back next to the AC connector. Then you'll have your: always off, always on (with another, simple switch on the front) & on on trigger signal.
Website: http://members.lycos.nl/anthonyvh |
#7 |
Why not put a short delay into the circuit as well. This will reduce popping in the speakers from the relay kicking in.
#8 |
Can some explain what the following parts from the suggested schematic:
1N4148 1N4004 BC547 Are the "En Signals" the trigger signals? thanks. |
#9 | |
The 1N4148, 1N4004 & BC547 are about the most general available diodes & NPN transistor you can find, in Europe that is. If you can't find them replace as follows: 1N4148: general low current diode (can easily fit in 5mm footprint) 1N4004: general diode (1A 100V) (fits just into a 7.5mm spaced footprint) BC547: general NPN transistor If you're not sure with what to replace, here are the datasheet to give you a general idea. They are from OnSemi (Motorola). As these are general parts, the characteristics should be the same no matter what brand you have. BC547: datasheet 1N4148: datasheet 1N4004: datasheet Know that I haven't tested this circuit yet! I'll probably will do so today. Note that the BC547 can only source 100mA continuously. If you're going to use a low voltage relay (eg. 6V) you might need to use another transistor, one that can source more current.
#10 |
Here is another Schematic that does the same thing.
| 12V Trigger for X150.5 | rc5al | Pass Labs | 8 | 15th December 2008 05:12 PM |
| 12V trigger problems | nyatt | Solid State | 11 | 26th June 2008 10:43 PM |
| Switching 230 Volt Transformer to 120 Volt | OMNIFEX | Parts | 10 | 6th April 2008 04:34 PM |
| 12v UPS relays Trigger, 1 ~ 11v no trigger | jacquesl | Power Supplies | 5 | 28th August 2007 05:30 PM |
| Type of 12V trigger on Amp? | Texaspledge | Solid State | 3 | 17th November 2004 05:19 AM |
| Page generated in 0.14014 seconds (71.78% PHP - 28.22% MySQL) with 11 queries |
