Old 18th May 2004, 06:17 PM   #1
Default Newbie Grounding question
Hello all. I recently finished my first DIY audio project by building a pocket headphone amp by following this page.
The amp works fairly well with good sound. However, there's a rather weird problem. When I plug it into my MPIO FL100 mp3 player (has a metalic casing), there's a noise not unlike when one is tuning an AM radio. This only happens when I touch the MP3 player ONLY. If I touch both, the noise disappears. If I change the source to my Sony Discman (plastic casing), I don't hear such noise. Also, if I change the source to a bookshelf shelf CD player, theres a horrible static noise that drowns out the music. What's going on here? Is this a grounding problem?
Old 18th May 2004, 08:40 PM   #2
Sounds like it could very well be a ground problem. Try touching the casings of both items with a length of wire (insulating yourself from all three) and see if the noise is reduced or eliminated.
I was getting horrendous hum out of a receiver when feeding it audio from my computer (I have a HTPC), but adding equal-length ground straps to all relevant pieces of gear cured it completely - I had some major ground-loop action happening.
oO
Old 20th May 2004, 03:06 PM   #3
There is no noise by doing that. I should also add that the noise only comes when I pick up the mp3 player by itself.
Old 21st May 2004, 03:04 AM   #4
Easyamp's Avatar
make sure your amps input ground is connected to you mini plug ground from your fl100. If it is try adding a 100k resistor from your input pin to the ground of the opa input which should be connected to the mini plug ground from the fl100.
Sounds like a simple differential ground plane issue. make sure all your grounds are the same.
Cheers
Old 21st May 2004, 07:23 PM   #5
I don't understand. How are they suppose to be connected? It's just one audio jack to another via a interconnect cable.
OPT grounding question Nihilist Tubes / Valves 16 2nd June 2009 02:06 AM
chassis grounding question mnr102 Solid State 2 12th July 2008 09:14 AM
Question about Star Grounding voivodata Tubes / Valves 2 20th March 2007 07:46 PM
Grounding problem question? excetara2 Solid State 5 10th November 2006 04:39 PM
grounding question skyraider Chip Amps 1 9th March 2004 09:12 AM
Page generated in 0.07686 seconds (72.80% PHP - 27.20% MySQL) with 10 queries
