| Chip Amps Amplifiers based on integrated circuits |
Hello..
Sorry for this stupid question.. I'm just a newbie in electronics my questions are: In my country when i buy a transformer i can only get an EI laminated tranformer and the only rating i know about the trafo is their current rating. Can someone explain to me the equivalent rating between Current and the VA value of a transformer? I have plans to build a gainclone, a Bridge parallel of OPA541/549(2 chips per sides) for 1 channel. What sould be the VA/Current rating of the trafo? |
#2 |
Electrons are yellow and more is better!
VA rating is (V*V)/R at the secondary side.
The current is V/R this is valid for RESISTIVE load. If you rectify and add smoothing caps the VA rating will drop. If you have a huge cap battery the VA will drop to half but as an average value the VA or DC watt out will be 0.9-0.7 of the VA of the transformer. 100VA => 90-70 watts DC continuously 100 VA + 100 000 uF => 50 watts or so out The VA rating is also dependent how you plan to use the amp. It's only about the temperature inside the transformer. When you have reached 105 deg C inside a toroid transformer you have reached the max VA out take. In your case I'll believe 150-300 VA is normal if you are going to use the amp at home.
/Per-Anders (my first name) or P-A as my friends call me |
#3 |
hi,
i know what you mean, the current rating as stated on the traffo has no meaning to me.... for gainclones, you can use 12-0-12 or 24-0-24 traffos, like those off deeco in raon...you can choose one that used a 1 1/4 in center leg.... for a bridged type gainclone, you can use two traffos, 12-0-12 and bridge rectify them to have separate plus and minus 35vdc rails.... http://www.diyaudio.com/forums/showthread.php?s=&threadid=30760&perpage=15&pagenu mber=5 tony
Placebo medicine works best when the doctor believes in it too. Next best is when the doctor is good at pretending to believe in it.DF96 |
#4 |
In my case i got 10 ampere dual secondary (2x25-0-25) trafo, is this enough for a sigle channel?
#5 | |
#6 | |
If it aint broke, don't fix it. If it is broke, fix it. If you can't fix it, take it apart and see how it "worked". |
#7 | |
please note that in my country, traffos are overrated, i do not know what standards are being followed if at all.... therefore, even if they state 10 amps secondary, it could very well be just the same as your 60va traffo... of course you can always get away with lower rated traffos, that's your call...
#8 |
JohnDoe,
from angeles city? i see your interested in building gainclones now JohnDoe. Good luck. |
#9 | |
but if that's all you GC need's then 60va is plenty. |
#10 |
Banned
But larger transformers sound better..........as they operate further from saturation.
Jocko |
| power transformer rating and tube current - SimpleSE | cbutterworth | Tubes / Valves | 17 | 12th June 2008 11:54 PM |
| Transformer current rating calculation | Roy3932 | Parts | 1 | 28th August 2007 05:25 AM |
| Current rating and tube current draw | cbutterworth | Tubes / Valves | 1 | 13th October 2006 05:42 AM |
| How to test transformer's current rating? | kmtang | Tubes / Valves | 6 | 12th September 2006 07:44 AM |
| choke current rating | metebalci | Tubes / Valves | 17 | 9th August 2004 09:51 AM |
| Page generated in 0.16098 seconds (63.11% PHP - 36.89% MySQL) with 11 queries |
