| Chip Amps Amplifiers based on integrated circuits |
#41 |
hi,
core is 1 1/2 in stacked to 3inches depth....weighs approx 8kg... no load voltages are: 1. 54 volts center tapped @ 12amps 2. 2x 12 volts @ 2amps with cover shells and painted flat black.. secondaries are bifilliar wound, voltage readings from either ends from the center tap are exactly the same..... i can deliver the traffo to your city, angeles...gusto ko ring makarating dyan!!! tony
Placebo medicine works best when the doctor believes in it too. Next best is when the doctor is good at pretending to believe in it.DF96 |
#42 |
Deliver and then clubbing... hhmmm.
Angeles City is soooo cool! |
#43 |
besides i have long wanted to go to AMERTRON inside clark airbase, my kumare is working there, time i paid her a visit...
johndoe, i can even make you one that is bigger than that....
#44 | |
Hahahaha. |
#45 | ||||
can u wait till next month? Quote:
#46 |
hi,
i have another option for you, i can go to your place, and i can teach your rewinder how to make traffos like i do.... this should lower your costs substantialy, you only have to pay for may passage.... tony
| power transformer rating and tube current - SimpleSE | cbutterworth | Tubes / Valves | 17 | 12th June 2008 11:54 PM |
| Transformer current rating calculation | Roy3932 | Parts | 1 | 28th August 2007 05:25 AM |
| Current rating and tube current draw | cbutterworth | Tubes / Valves | 1 | 13th October 2006 05:42 AM |
| How to test transformer's current rating? | kmtang | Tubes / Valves | 6 | 12th September 2006 07:44 AM |
| choke current rating | metebalci | Tubes / Valves | 17 | 9th August 2004 09:51 AM |
| Page generated in 0.09502 seconds (73.82% PHP - 26.18% MySQL) with 11 queries |
