| Chip Amps Amplifiers based on integrated circuits |
#21 |
You want's some opa541?? I've got em, I have 2 for whoever wants them. They were samples from awhile ago.
first 2 reply get's them. |
#22 | |
If u can send it here in the philippines,, why not... Ti's doen't have a stock for opa541 and 549...I'm still waiting for my order(sample) since last month.... |
#23 |
I'll send them But I ask that you pay for the shipping. If interested email me your address to support@easyamp.com and I'll give you a shipping cost.
Cheers, |
#24 | |
Do they? I mean, maybe they sound better but do they operate further from saturation? As far as I know saturation and maximum flux is determined by the primary voltage (higher voltage, more flux) and frequency (lower frequency, more flux) and not by secondary current. Even a small transformer can supply a lot of power, but only for a short moment because of overheating, not because of supposed saturation. Steven
The Analog Art shows no sign of yielding to the Dodo's fate. The emergence and maturation of monolithic processing finesse has perhaps lagged a bit behind the growth of the Binary Business. But whereas digital precision is forever bounded by bits, there is no limit excepting Universal Hiss to the ultimate accuracy and functional variety of simple analog circuits. - Barry Gilbert, 1973 |
#25 | |
has suggested an alternative solution which is in line with your reasoning. Use two transformers instead of one and connect their primaries in series, thus underrating them. You also need to connect the secondaries in series two and two, or choose transformer with a different rated secondary voltage. |
#26 | ||
I havent tried the resistor/ohms law method yet.
If it aint broke, don't fix it. If it is broke, fix it. If you can't fix it, take it apart and see how it "worked". |
#27 |
these are traffos handmade by me, smallest at 15va, biggest is 3000va...
Placebo medicine works best when the doctor believes in it too. Next best is when the doctor is good at pretending to believe in it.DF96 |
#28 | |
Hey Bro.. nice trafo! can u send me the big one? hehehe... How much the maximum current rating for that trafo(the big one)? Are you going to sell that? if yes, for how much? |
#29 |
hi,
the BIG one is intended for a leach amp that can do 1000watt per channel at 2ohms...it weighs in at around 25kilos... specs are: 1. primary 220volts 2. secondaries: main= > 120volts center tapped, auxilliary windings, 140volts center tapped at 1amp, 12 volts at 2 amps the one beside it with a copper banding is suitable for a bridged gain clone and can power up to 6 chips....i can sell that to you if you need it..... or i can make one custum wound to your specs... all my traffos have secondary windings that are bifilliar wound, i know of no other winder in manila doing biffiliar secondary windings besides me....
#30 |
Tony,
Good luck with those trafos, you'll need a gorilla to move your gear around the house with that size. Johndoe, You can use wahtever resistors you have, just match them with a good DMM and your off. This is audio electronics, not rocket science. JojoD |
| power transformer rating and tube current - SimpleSE | cbutterworth | Tubes / Valves | 17 | 12th June 2008 11:54 PM |
| Transformer current rating calculation | Roy3932 | Parts | 1 | 28th August 2007 05:25 AM |
| Current rating and tube current draw | cbutterworth | Tubes / Valves | 1 | 13th October 2006 05:42 AM |
| How to test transformer's current rating? | kmtang | Tubes / Valves | 6 | 12th September 2006 07:44 AM |
| choke current rating | metebalci | Tubes / Valves | 17 | 9th August 2004 09:51 AM |
| Page generated in 0.12919 seconds (74.61% PHP - 25.39% MySQL) with 11 queries |
