| Chip Amps Amplifiers based on integrated circuits |
#11 | |
Thanks for info Joan2!!
since raon(Manila) is 3 to 4 hours away from Angeles city I cant find time to go there. Is there any toroind trafo here in our country? by the way, were you in manila? Quote:
What 'bout you JojoD818? were u from? |
#12 | |
runs cooler too!! tony
Placebo medicine works best when the doctor believes in it too. Next best is when the doctor is good at pretending to believe in it.DF96 |
#13 | |
i'm from pasig city....unfortunately i don't know any torroids in manila except those from discarded japanese amps, i am working on one...last time i made a torroid was in early 90's which i used for a leach amp.... believe me, you will miss nothing from not having a torroid except perhaps its small outline as compared to an ei of same va rating... i have built lot's of amps using ei's that are stone quiet rvrn eith volume controls turned all the way up.... tony
#14 | |
If it aint broke, don't fix it. If it is broke, fix it. If you can't fix it, take it apart and see how it "worked". |
#15 | |
I'm from Valenzuela City. Malinta exit from NLEX. |
#16 | |
this just goes to show that our listening levels average in the 2watt or so levels....
#17 | |
Not that that means much, but I was told the design would output 100W+ into eight ohms. I dunno, its loud enough for my liking.
#18 | |
even if your woofer was rated at 350w it could still be damaged with a 2watt sine wave input...
#19 |
I'm not sure what to say, either I'm missing something or you guys are pulling my leg.
Even giving that most dmm's measure rms and not peak of the sine you would still only gain 1.41 times 2 watts which is the peak of the sine wave. If you pump a 2 watt 40hz sine wave into a speaker that is rated at 350w (rms or peak not real important here considering the safety margin) and the speaker bottomed then either the speaker is rated for less then 2 watts or something’s a miss in the measuring. The before stated .5A peak current load was the rail current not the output current and if this is a standard class AB GC then this .5a figure doesn't translate to output directly. The output depends on the efficiency of the amp, which is not 100% so the output will be less then supply. I've seen figures for some class A amps efficiency of less then 10%(output level dependent), I'm not real sure about AB GC's. I’m curious how you are measuring the current load of your amp this could be the misleading point. You said before you are running a mixed bridge parallel configuration, are you measuring in front of one of the chips or right after the bridge and filter caps, or the ac going into the bridge/caps? If you are using a dmm check that it will measure other then 60hz ac current if measuring after trnsfo I've had this problem before. I stick a low value power resistor in line with one of the rails (.22 ohm or something) and measure the voltage drop and use ohms law to find current if I'm curious about the current load. Also I'm curious of the voltage drop across a .22 ohm in line with the speaker at full volume, should be around a few volts if bottoming a 350w speaker. You can make a lot of power from mixed bridge parallel GC's setup and I wouldn't be surprised if you bottomed out a driver but not with 500ma. Cheers |
#20 |
Hey Jojod818!!
Bro. I saw u're Parallel/bridge set-up in your website, got some questions!, did u use .1% or 1% res or special component for that set-up? how did u manage to match the output? I'm planing to use opa541 in inverted setup(parallel/bridge) do u think this will work? what will be the maximum output power for this set-up? Money and time for me is to tigh, gathering an info and safty measures before building it is my fist concern. one more thing, can i use 5% resistor? i cannot find .1% not even 1% resistor anywhere in angeles city. |
| power transformer rating and tube current - SimpleSE | cbutterworth | Tubes / Valves | 17 | 12th June 2008 11:54 PM |
| Transformer current rating calculation | Roy3932 | Parts | 1 | 28th August 2007 05:25 AM |
| Current rating and tube current draw | cbutterworth | Tubes / Valves | 1 | 13th October 2006 05:42 AM |
| How to test transformer's current rating? | kmtang | Tubes / Valves | 6 | 12th September 2006 07:44 AM |
| choke current rating | metebalci | Tubes / Valves | 17 | 9th August 2004 09:51 AM |
| Page generated in 0.11845 seconds (83.88% PHP - 16.12% MySQL) with 11 queries |
