Where to buy Tripath chips in US? - Page 2 - diyAudio
Old 18th May 2004, 07:38 PM   #11
KCHANG is offline KCHANG  United States
Default My speakers
I actually have two Tripath amps. One uses the 0104A evaluation board and supposedly can produce 200W/channel. I built this one. It is now in my main system driving two B&G RD75 line-source drivers. An 120W/channel NAD amp is also used in the main system to drive two open-baffle dipolar subwoofers (each with four 18" subwoofer drivers) that cover the bass range from 180Hz down.
The second Tripath amp is the Blaupunkt car amp I mentioned in earlier posts. I used it for a brief period to drive two Fostex FX200 drivers on large (3'x4') open baffles. That system is augmented in the bass with a subwoofer driven by a plate amp.
I am new to this forum, having posted my first message last Friday.
Kurt
Old 18th May 2004, 08:16 PM   #12
dmason is offline dmason  United States
It is because of the newly discovered superb synergy between Tripath and Fostex with Omega owners, that I pursue the lower powered chips. Noticing your FX200, wondering how that worked out. Feel free to email me with particulars.
"Pilau Buggah, Big Islan Mo Betta!!"
Old 19th May 2004, 04:07 PM   #13
Default FX200 with Gainclone
Hi dmason,
The FX200 on open baffles worked out very well. Among all my various speaker projects, the FX200 system currently is the one I enjoy listening to the most. It is amazing what kind of good sound (to my ears) one can get from $350/pair drivers on simple boards plus an inexpensive subwoofer.
There seems to be some synergy between fullrange drivers and the Gainclone as well as good digital amps. Last weekend I helped a friend build open baffles for his Supravox field-coil drivers and 21" dipolar subwoofer drivers. With the speakers driven by the battery-powered Gainclone the result was quite excellent. I am sure that the speakers would also sound good with a Tripath amp or the Panny receiver.
Kurt
Old 19th May 2004, 04:29 PM   #14
Kurt, Is there available information on open-baffle sizing for Fostex??
I am thinking along the lines of narrow-ish baffles, 36X12" or so, on veneered board, angled at 5 degrees, used in series with a tiny 7" sub, powered by either a JVC RX-F10 or a Tripath EA2050.
The posts relating to use of the Tripath Griffin Powerwave 15 watter with Omega-Fostex BR on audiocircle.com are very enlightening.
Old 19th May 2004, 05:38 PM   #15
Default baffle design
Hi dmason,
There are many posts at the full-range driver forum (http://f18.parsimony.net/forum31999/ )that talked about the design of open baffles, and you should be able to find (or ask for) the links to two tools for modeling open-baffle response.
Generally, however, a 12"-wide baffle may be too narrow to allow the fullrange driver to go down to a point (e.g., below 200Hz) where you can cross in a subwoofer easily. It may still work though with some high-Q drivers, but some experimenting will be required.
Kurt
Old 20th May 2004, 07:49 AM   #16
lucpes is offline lucpes  Romania
Send a message via Yahoo to lucpes
Default Re: baffle design
Originally posted by KCHANG
Hi dmason,
Kurt
Kurt, can I have your input in this thread?: 'reference' speakers idea (ribbons & sealed bass bins)
Thanks!
PS. Sorry for going OT here...
We should no more let numbers define audio quality than we would let chemical analysis be the arbiter of fine wines. Measurements can provide a measure of insight, but are no substitute for human judgment. Nelson Pass
List of products using Tripath Chips motherone Class D 35 10th October 2013 10:44 AM
Tripath chips shootout oon_the_kid Class D 10 31st May 2009 01:53 AM
Where do I get Tripath Chips??? Rod_T Class D 8 28th October 2007 01:35 AM
Where to buy tripath chips? bigmike216 Class D 1 27th August 2005 06:31 PM
tripath chips supplier CRFX Parts 2 21st November 2004 07:59 PM
Copyright 1999-2017 diyAudio
