| Chip Amps Amplifiers based on integrated circuits |
Hey mod team, if this needs to be over in another section, please feel free to throw it there.
A BUNCH of folks have been following my LM4780 paralleled amp project, and I've gotten a number of E-mails asking about buying boards. I mean, a NUMBER of E-mails. I'm an old hand with bulk-buys, having orchestrated the moving of several thousand white LEDs direct from Nichia Chemical Corp. in Japan (and correspondingly several thousand dollars from about a hundred people), so I'm debating another bulk-buy - this one of PC boards of my paralleled LM4780 design. The board will be double-sided with plated holes and vias, full solder masks and silkscreened parts locations. Each board will be 3.8" by 2.5" and will contain TWO AMPLIFIER BOARDS, panellized. These can be hooked up in parallel to double output power or run separately for stereo. With a supply voltage of 60 volts rail-to-rail the amps should hit 120W RMS into an 8-ohm load. The board design includes integrades close-to-chip decoupler cap mounting points as well as integrated thumpless mute. The design has thus far proven itself surprisingly immune to noise and hum. You'll need to provide appropriate supply filtration and run the mute connect points to some form of SPDT switch or relay. Additionally, the board is designed first and foremost to be compact - its connect points are for soldered wire, not terminals or connectors. It's not meant for temporary installation. I don't do bulk-buys until I do a feeler, as standard policy. To that end I have posted a feeler page in the Wiki for everyone interested to post their desired quantity of boards. The more the cheaper, and price per board is posted in the Wiki page. Wiki paralleled-LM4780 board feeler page Pics of the prototypes will come shortly. oO |
#2 |
#3 |
A quick bump...
oO |
#4 |
How might your board design differ from Brian's and Peter's would you se yours haveing a advantage
Jack Head |
#5 | |
That's the downside to having several people come up with working board designs at the same time - it's almost an eeny-meeny-miney-moe type thing to choose a board! oO |
#6 |
Then I guess it might also come down to the end price to purchase as well as ease to build and aquire parts
Jack Head |
#7 | |
![]() BTW, you use Zobel, right?
www.audiosector.com “Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC |
#8 | |
No Zobel, unless you count the load-balancers the chip calls for in parallel as they sure look like Zobels to me. Personally I think the three of us with 4780 boards should swap a board with each other and then come up with a single design that kicks the most backside. But, that's just me. ![]() oO |
#9 |
The PS caps seem to be rather small, what dia. are those?
#10 | |
Something has to give in order to provide for a small footprint - in this case the supply-rail filters are off-board. Seems to work rather well in my tests though. ![]() oO |
| 8x Mur 860 strong enough for 2 paralleled 4780? | Bassterror | Chip Amps | 4 | 8th February 2007 01:02 AM |
| Bridging board for 4780 | G.L. Tirebiter | Chip Amps | 1 | 14th December 2005 11:05 PM |
| Atlas 15 feeler | path914 | Swap Meet | 3 | 1st December 2005 07:34 PM |
| Help with my 4780 board? | Kevin Haskins | Chip Amps | 3 | 20th September 2004 07:28 PM |
| Paralleled LM4780TA PC board design - How's this look? | OddOne | Chip Amps | 17 | 4th May 2004 01:21 AM |
| Page generated in 0.11114 seconds (79.58% PHP - 20.42% MySQL) with 10 queries |
