Chipamp as preamp?
Chipamp as preamp?
Old 12th May 2004, 03:27 PM   #21
carlosfm is offline carlosfm  Portugal
Banned
Originally posted by officeboy
Something like Texas Instruments TL072, or On-semi's MC33078, or Nationals LF412 or LMC662?
Old 12th May 2004, 03:31 PM   #22
officeboy is offline officeboy  United States
Send a message via MSN to officeboy
Originally posted by carlosfm
Hah, I have no idea, thatís why I'm asking.
I just looked around for what they called low noise, fast op-amps.
ESP recommends FET type op-amps so that's what Iím trying. (Itís just for a sub crossover so not a huge deal)
Old 12th May 2004, 04:03 PM   #23
Banned
Why didn't you say so?
Anything will do, and commercial designs always use the worst they can get (TL072, LM324...).
For peace of mind, and knowing that good op-amps also have better bass , when I made my Sub I used the OPA4228.
Very silent, very good, quad op-amp (or the 2228 for double) and curiously works very well with gains of 1 (buffer), despite of what BB/TI says in the datasheet.
Old 13th May 2004, 02:06 AM   #24
lumanauw is offline lumanauw  Indonesia
diyAudio Moderator Emeritus
lumanauw's Avatar
Send a message via Yahoo to lumanauw
I have done the parallel opamp thing for headphone amps
Please tell me how to parrarel opamps. It has 3 pins, +input, -input, output. Does parrarel several opamps is directly tied these 3pins with each other? Or have to put small value R for every opamp? Got picture?
Old 13th May 2004, 02:32 AM   #25
HDTVman is offline HDTVman  United States
I built a small headphone amp for a friend using 2 TLO84s Quad opamps( one for each channel) and a TLO82 dual opamp.
The 84s had all of the + input for each chip tied together with a 100 ohm resistor inseries with the chip. The - input of each opamp was tied to the output of that amp with a 100 ohm resistor. the outputs were all connected together with 10 ohm resistors in series. This give an output current rating of about 70 - 80 ma. The TLO82 was set up as the gain stage driving the TLO84 buffers.
Not the greatest headphone amp in the world but not bad. Real cheap to make and very dependable.
Later BZ
What ever makes the tunes flow
Chipamp as preamp?Hide this!Advertise here!
preamp for chipamp getafix Chip Amps 1 17th October 2007 10:49 AM
what preamp do you use with your chipamp? jarthel Chip Amps 5 26th June 2007 11:35 PM
chipamp passive preamp / crossover DoomPixie Chip Amps 4 23rd October 2006 09:13 PM
Preamp specs for a chipamp zenon Chip Amps 13 21st May 2006 12:15 AM
chip preamp for my chipamp? Russ White Chip Amps 3 9th March 2005 03:51 PM
