Old 12th May 2004, 05:05 AM   #11
Tensop is offline Tensop  Lebanon
isnt mute meant to be coupled via a resistor and capacitor to -VE, not gnd?
Old 12th May 2004, 06:06 AM   #12
janneman's Avatar
Location: Where Germany, The Netherlands and Belgium meet
When you bridged C3, the input cap, you made it a DC amp. Any stray DC from the preamp or whatever you drive it with is amplified. The advice given was NOT to take out C3, but to put a resistor from the +input to ground (22k was suggested). That will solve the unbalance in bias while still maintaining the AC coupling.
Be really carefull by doing random things, unless you fully understand the implications. The chip amps may be cheap, the speakers probably not.
Jan Didden
/Another new issue: Linear Audio Volume 3!
Old 12th May 2004, 03:18 PM   #13
Yes, I was supposed to move R5, not short C3, but as it was easier to short C3 I did that instead. I figured that it wouldn't cause too many problems, since C7 ensures unity gain at DC. I also tried to connect a speaker with the input shorted and get the same results.
I will fix it properly (move R5, unshort C3) on my lunchbreak today and see if that helps at all.
I believe that R1 couples mute to -Ve and C1 to ground, as shown in the datasheet.
Old 12th May 2004, 03:28 PM   #14
Electrons are yellow and more is better!
peranders's Avatar
Mr. rayban, in cases like yours and in many other also, I really recommend you to read the datasheet first and all application notes before you trust an unknown website and circuit design. Start with comparing and make up your own opinion. It can be hard to understand what the datasheet says but at least there usually is a typical application and connection.
Normally you have good info there to start with and if you want you can tweak" the design.
/Per-Anders (my first name) or P-A as my friends call me
Old 12th May 2004, 03:58 PM   #15
I thought I had read all the materials
This circuit is identical to the datasheet (other than my mixup with R5 and C3 which is now corrected)
I don't really want to tweak the design, well not yet anyways , I just want to make it work properly.
diy cables and tone sucking? bryanteoh Everything Else 7 23rd December 2007 04:08 PM
Current feed back again.............. ashok Solid State 0 15th November 2004 06:54 AM
Gainclone PS current? rafalc Chip Amps 4 20th July 2004 09:49 PM
Page generated in 0.08737 seconds (73.75% PHP - 26.25% MySQL) with 11 queries
