| Chip Amps Amplifiers based on integrated circuits |
It goes through 2 fuses about once a week. I am not running a pot with it but I try to stop the music before I turn off the amp.
Rite now I am just letting it run all the time. |
#2 |
Electrons are yellow and more is better!
You might need a soft starter or at least bigger fuses.
Inrush Current Limiting Circuit http://www.diyaudio.com/forums/showt...809#post231809 http://www.diyaudio.com/forums/showt...ht=#post365890
/Per-Anders (my first name) or P-A as my friends call me |
#3 |
Some details may help!
Size of transformer, size/type of fuse, circuit used.
The truth need not be veiled, for it veils itself from the eyes of the ignorant. |
#4 |
In my case, 400VA toroid, I had also blown fuses untill I started using bigger values (even 5A was not enough sometimes, and now 6A is what I use). The fuses were blowing because of high inrush current when powering toroid.
#5 |
I am confused AJ
Blowing fuse by turning power amp off while music signal continue to feed the amp? Chris |
#6 |
What's to say it's the primary fuse that blows?
We need circuit and values to diagnose properly. Rune
Do wizards use spell checkers? |
#7 |
Ok here is what I am running.
BrainGT's PCB gainclone This is the torroid I am using http://www.partsexpress.com/pe/pshow...number=122-640 This is my power entry module http://sales.goldmine-elec.com/prodinfo.asp?prodid=9312 rite now I am running (2)2a slow blo fuses. |
#8 |
try using a bigger fuse , say 2.5 or 3 ampere (slow blow). toroidal transformers cause quite an inrush current. I'm using a 2a fuse with a 225va transformer but i blow this one about once every two weeks.
You could of course use an ntc / thermistor in one of the lines powering the toroid. Sort of a very basic soft-start. |
#9 |
When it comes to fuses there are normally recommended values from the transformer manufactures. Think about WHY you have fuses also.
I can speak for my own sake, 600 VA and 60 000 uF can't an automatic 10 A fuse take. The fuse in the amp is 4 of 5 AT (don't remember) at 230 VAC. Maybe my soft starter is the solution?
#10 |
I guess in 120V countries inrush current are even more, so higher fuse values apply. I can't use an amp with anything less than 5A fuse (for 400VA toroid).
| Help, new PSU blowing fuses | TDWesty | Chip Amps | 14 | 4th March 2007 07:29 PM |
| nad 214 where are the fuses? | gregkitchen | Solid State | 1 | 18th August 2006 11:35 PM |
| Fuses | rtarbell | Parts | 7 | 8th November 2005 03:14 PM |
| amp bridging eating fuses, but load seems ok | da_madaxeman | Chip Amps | 3 | 28th April 2004 11:03 AM |
| Quad II eating valves? | Zombie | Tubes / Valves | 31 | 26th February 2003 05:29 PM |
| Page generated in 0.12815 seconds (82.72% PHP - 17.28% MySQL) with 10 queries |
