I'm searching for a suitable heatsink for the LM3875.
Can you help me with this?
I understand there are variables to be considered.
Can I assume an average Pd, W of 20?
Can I assume a max air temp in the enclosure of 50 C or 122 F?
Can I assume |V| +/- is 40 or less?
Looking at page 8 of the data sheet leads me to believe that a heatsink thermal resistance of 3.8 C/W or less is fine.
Is this correct? And are my assumptions reasonable?
Thanks in advance.
Thanks in advance.
bg40403 said:I'm searching for a suitable heatsink for the LM3875.
Thanks in advance.
Well, the power dissipation per channel wouldn't even get close to 20W unless you were feeding it a continuous test tone at maximum power, and unless your room is extremely hot, or you plan on having the chips in a virtually air-tight enclosure, 50°C would be a much higher air temperature than I would expect. I don't know what your rail voltages are, but in most cases, a "real" heatsink isn't necessary, and large (1/2-1 pound) plate of 1/2" think aluminum would work very well. If you can't easily get acess to that, I think one of the best and most economical solutions is to use an old slot 1 heatsink. Compusa's
part number 50077044 with the fan removed should be well suited for two LM3875's, but it's sold out, and I don't know if that's temporary or permanent. Part number 50077045 is identical, except that it comes with two fans and costs about twice as much. I think it's still a fairly good deal, especially if you have a Compusa nearby and can just go pick it up without paying for shipping.
I have my chips mounted on a wider PII heatsink with shallower fins, and they never get noticably warmer than room temperature at comfortable listening levels. They only get warm with a continuous sine wave input just below clipping (to measure power output), but it's unlikely that you enjoy listening to very loud sine waves, so any decent-sized pentium two heatsink should be just fine.
the national design will reveal all;
http://www.national.com/appinfo/audio/files/Overture_Design_Guide14.xls
