Gainclone output resistor
Old 6th May 2004, 12:40 PM   #11
jackinnj is offline jackinnj  United States
jackinnj's Avatar
i ran a multisim bode plot (1Hz to 100kHz) using 10R and 0.1R resistances with 0.7uH inductor -- the load was the ESP simulated speaker, with simulated inductances, capacitance and resistance for 10 feet of Monster Cable -- the "gain" is the difference in gain between the two versions:
Old 6th May 2004, 12:56 PM   #12
jackinnj's Avatar
maybe this is a little clearerrrrrrrrrrrrrrrrr -- the attenuation of the 0.1R and 10R on the simulated speaker/cable
Old 6th May 2004, 01:23 PM   #13
BlackBLOOD is offline BlackBLOOD  Bulgaria
10x for the advice
Need advice on someting else.
how to mesure the output power of the amp in Volts?
my pre amp is integrated on my sound card and my amp is working on 1V input signal max.
I need to know what will be my siound card output max voltage...
Old 6th May 2004, 01:35 PM   #14
jan.didden is offline jan.didden  Europe
jan.didden's Avatar
Originally posted by Hybrid fourdoor
Whats the wattage rating on the resistors if using <0.5 Ohm? 5W? 3W?
Since most of the current is going through the choke at low/mid freqs, the resistor can be small wattage. If you use the resistor as 'body' for the coil just chose the resistor from that pov. The resistor DOES carry the current for high freqs, but these signal levels are very low (avarage) anyway, so again the resistor choice is more determined by the required physical dimentions. A 1 W res would do anyway.
Jan Didden
Cable: a potential source of trouble interconnecting two other potential sources of trouble - Erik Margan
Linear Audio pubs and articles . The SilentSwitcher now at diyaudio store SilentSwitcher. Keeping in touch with SY.
Old 6th May 2004, 02:37 PM   #15
JojoD818 is offline JojoD818  Philippines
JojoD818's Avatar
Originally posted by peranders
You MUST have resistors if you connect the LM3886 in parallel but if you only have one IC you can have nothing or the inductor. This depends of your load and cable lenght. You can have this resistor also if you wish but start with as little as possible at first. My examples gives you a DC resistance of 5 mohms.
Hi peranders,
I am currently building my latest stereo GC project that uses only one IC per channel and already bought a pair of 0.1 and 0.22 ohm 5W resistors and several 10 ohms 2 watts. I also have some spare magnet wires from a passive crossover network project so I have the things that I need. I am seriously considering the inductor.
My last question is, for capacitive loads (such as cables), is the inductor only any good?
JojoD
Old 6th May 2004, 09:24 PM   #16
zygibajt is offline zygibajt  Poland
You need to "protect" your power amp from capacitive loads that would cause instability (typically "ringing" ).
This small value resistor at the output doers nothing to protect the amp from capacitive loads.
GC is very sensitive to this kind of loads.Take a pair of speaker cables that measure more than 1000p (there are many on the market) and connect "not easy" speakers withe them to GC.It will crack /distort like hell no matter the resistor is there or it isn't.
Only Zobel fixes that ,but it makes the amp sound worse.
Bartek
Old 7th May 2004, 08:46 PM   #17
tlmadsen is offline tlmadsen  Denmark
tlmadsen's Avatar
I am sorry "zygibajt", but a small resistor (0.1 - 0.5 ohm) does indeed protect your amp from capacitive loads.
Try the following experiment. Take a amp with no kind of output resistor or inductor. Connect it to a resistive load, like 8 ohm. So far you should be fine. Now connect a capacitor at about 100 nF across the resistive load. If you are "lucky" you can see evidence of unstability as sign of oscillation in the 100-500 kHz area. You might have to "adjust" capacitor to make it happen.
(with your "crack /distort like hell " it should not to to difficult)
When you have the "oscillation" put the small resistor between the amp and load. You "oscillation" are completely gone.
Hmmmmmmmmmmmmmmmm, how surprisingsly it may sound, the Zobel network "protects" the amplifier from inductive loads and I have a very hard time seeing how it can make the amplifier sound worse, so please explain.
Thomas
Old 7th May 2004, 09:26 PM   #18
All I'm saying is based on my experiments with GC,not theory.
GC doesn't like high capacity speaker cables,and with some speakers going with the cables higher than some 400-500p makes GC crack and distort.I have some audophile quality cables that measure 1,4nF for 3meters long.It's impossible to listen to the GC on that cables,it distorts like hell.In every case of GC distorting small series resistor made no diffrance.Only 100n in series with 1ohm resistor to ground fixes this.With Zobel at the output even those high capacity cables sound fine,but that Zobel makes the amp sound worse,checked it many times.
Bartek
Gainclone output resistorHide this!Advertise here!
preamp output stage resistor from output to V- ? ? Bernhard Solid State 4 19th October 2007 02:55 PM
Why does the inverted gainclone have a resistor at the output goldyrathore Solid State 10 12th April 2005 11:36 AM
why a cap and resistor at output of leach? Wagener Solid State 2 13th August 2004 07:08 PM
5% output resistor xplod1236 Parts 4 31st July 2004 12:29 AM
GC 0,22R output resistor 2Bak Chip Amps 15 3rd March 2004 07:19 AM
