Old 30th April 2004, 11:41 PM   #1
roibm is offline roibm  Romania
Banned
Question How much DC is to much?
So guys, I am somehow worried about my gainclone's DC output(~85mV and ~65mV).
My question is: how much DC is too much? What valued qould probably blow the speakers(tweeter)?
This is somehow a general question, and I believe of much interest for many.
Any comments are welcomed!
Old 1st May 2004, 12:51 AM   #2
li_gangyi's Avatar
most of the time under 100mV will work...but some people believe 0mV is good practice...
Kids in the back seat cause accidents...Accidents in the back seat cause kids...
Old 1st May 2004, 05:17 AM   #3
roadkill's Avatar
85mV offset should not matter much, most woofers will take this quite well. Heat dissipation will be just 0.9 mW for an 8 ohm speaker. Tweeters should be connected through a capacitor, even if you are using an electronic crossover, so the DC offset will not cause problems.
Old 1st May 2004, 05:26 AM   #4
Make sure you check this with the inputs shorted. I thought I had 65mV of DC offset, it dropped to < 10mV when I shorted the inputs.
Old 1st May 2004, 09:56 AM   #5
Banned
Well, what I tested was how much DC is going to my speakers under normal operation.
So the system was playing music, it was not without inputs or under no load. I think this is a fair test. Am I wrong?
Old 1st May 2004, 10:50 AM   #6
Default Re: How much DC is to much?
The tweeters should be protected, as long as they have a blocking capacitor in the xover.
What gainclone circuit are you using? IGC?
If you do, are you grounding the non-inverting input or using a resistor from it to ground? A resistor will probably cut the offset.
Carlos
Old 1st May 2004, 11:38 AM   #7
pinkmouse's Avatar
This may be a problem in terminology or translation, but if you short a chip's output to ground then what do you use as a reference to measure offset from?. This doesn't seem quite right to me
Al
I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort
Old 1st May 2004, 02:15 PM   #8
Short the inputs, not the outputs.
Basically the idea is to feed absolutely nothing into the amp, and then see what the voltages are doing. The ultimate would be to see zero DC and zero AC with input terminals grounded, but there'll usually be some tiny amount of AC/DC from the amp's bias point, diode junction noise, RFI/EMI coupling, etc. etc. etc.
With my luck I'm just happy as I can be when I apply power and the magic smoke doesn't escape.
oO
Old 1st May 2004, 04:08 PM   #9
What he said. Short the inputs I'm not sure what noise my amp was picking up with the inputs floating, but it showed up as DC on the output. This was measured with a DMM though, I don't remember if I put a scope on the outputs or not.
Old 1st May 2004, 04:31 PM   #10
pinkmouse's Avatar
Ok, so I can't read...
Al
Page generated in 0.09628 seconds (80.50% PHP - 19.50% MySQL) with 10 queries
