IGC with High input impedance!
Old 30th April 2004, 06:03 PM   #1
GregGC is offline GregGC  Canada
Lightbulb IGC with High input impedance!
For the ones that need higher input impedance and like the Inverted topology thatís what I came up with. Itís a popular way to control the gain of an opamp, but I havenít seen it applied in the IGC.
The shown sch has input impedance of 47k but you can go to 100k if you need to by changing R4. Youíd need to change the two 220k res to 470k so that the gain stays the same. The AC gain is ~ (R2/R4)*(R6/R5). So you can play with the values, though try to keep R6/R5 as low as possible because the same two resistors determine the DC gain of the amp. The lower the DC gain, the lower the Output offset. Also to keep the offset low (single digit mVís) keep R1 and R2 the same value (1% tolerance if possible). On the other hand R1 and R2 shouldnít be more than 470k (noise susceptibility).
/Greg
IGC with High input impedance!Hide this!Advertise here!
High input impedance X circuit zelter Pass Labs 4 31st March 2009 11:06 PM
Tuning 604 Project - High Q and High Output Impedance? Seadweller Multi-Way 20 18th February 2008 08:49 PM
Low amp Impedance input and high dac output tulip Tubes / Valves 1 30th November 2007 09:24 PM
How high is the input impedance of 'a' jfet transistor? Hans L Parts 2 14th September 2006 03:49 PM
P3A question: high input impedance sobazz Solid State 1 14th July 2003 06:45 AM
Copyright ©1999-2017 diyAudio
