| Chip Amps Amplifiers based on integrated circuits |
#11 |
You don't say which Velleamn protection module that you looked at!
If it was the 4700, that is a stereo module which will protect both channels and give protection during powering up you amps. The other Velleman protection modules are self-powered and you will need one per channel. If you get too much DC on the speaker terminals of your amp, it will destroy your speaker coils. If your amp is built well, there shouldn't be too much risk but if you have expensive speakers, a protection module will provide peace of mind.
The truth need not be veiled, for it veils itself from the eyes of the ignorant. |
#12 |
i have some boards going out for production next week -- these are like my chipclone boards, but with a dual op-amp and spaces for Sallen-key components. the way i configured it you can use jumpers to go from 1st to 4th order.
in the interim, you can always look at an XO incorporated design at; http://www.tech-diy.com/Chipamps/jbl_LSR25P.jpg |
#13 |
Sorry, I was looking at the Parts Express site and they only had one Velleman speaker protection circuit kit. Silly me, thought a place like that would have the whole line. Anyway, I checked out the velleman-kit site and they don't seem to sell directly. They have some local dealers, but neither of them have it in stock. I googled velleman 4700 and very little came up. Will this be that rare occasion where trying to order it will be more of a PITA than anything else?
My speakers are not expensive, but for a student, not cheap enough to forget about. Is a voice coil either fried or not, or are there stages of "burn"? I recently pulled the drivers from the original closed boxes to make a vented speaker for a project, and it appeared to me that the cone was somewhat pushed outward, although the spider was flat. Also, the fs was 64 hz rather than the published 38 hz. I know that information is not always correct for a particular driver, but just wondering if these could be symptoms of a driver that has had a rough unprotected life. thanks |
#14 |
This is the mains operated Velleman 4700 with the power up delay.
The other Velleman protection module has no PSU and is smaller. Yes, there are different degrees of cooking your speakers ranging from making the sound a bit distorted to not playing at all.
#15 | |
It should be fairly easy for a two way. What circuit are you using? Inverting or non-inverting? Up to third order should be fairly easy to use, just at the input. On the NIGC you can also use them on the feedback of the bass stage. Carlos |
#16 | |
#17 | |
Jan Didden suggested a similar way to go about active amping using regular power amps. some time ago in The Audio Amateur. Now if you tell me you will loss signal level with the filter or other claims that's fine. But it deserves a try. Carlos |
#18 | |
| (Gainclone Preamp) ACTIVE or PASSIVE ? | nickthevoice | Chip Amps | 27 | 26th July 2011 10:28 AM |
| Setting up a ESP active crossover with gainclone | Dan_Steele | Chip Amps | 57 | 31st August 2007 10:51 AM |
| Bad combination? | Kongen | Multi-Way | 18 | 1st December 2004 11:52 PM |
| Gainclone for an active subwoofer | m127 | Chip Amps | 13 | 19th November 2004 02:47 PM |
| Gainclone amp with DAC in active speakers | borges | Chip Amps | 15 | 16th April 2004 07:13 AM |
| Page generated in 0.10774 seconds (76.71% PHP - 23.29% MySQL) with 10 queries |
