| Chip Amps Amplifiers based on integrated circuits |
I figured i'd post a quick pic. This is my progress so far on an 8 channel amp, 6x gainclone and 2x p3a. Should be interesting to compare the two readily. I'll keep everyone posted on the progress
![]() power supply etc. info to come in a week or so! -Matthew K. Olson |
#2 |
i think you should use more shorter cables,and strong the caps base.
what meaning is p3a? -digi |
#3 |
Its a big chassis...so i can't use shorter cables.
Its ok though, i don't mind. The chassis will have 625va toroid on the p3awww.sound.westhost.com project 3a and 40kuf per rail and then gainclones ...all 6 channels will be fed by a 625va toroid w/ 25kuf per rail or so..plus the 1.2kuF at each chip...should be plenty ![]() -Matthew K. Olson |
#4 | |
![]() for stability the caps,i have an idea.you may make a few adjustments: split supply to 2x +/-rail use 1.2kuF big caps.one pair of caps for every channel,and setup to star ground of the chassis. The near chips caps use small pairs,such as 220uF/63v FC. -digi |
#5 |
I think this'll be close enough to what you're saying. You'll see. I'll post more pics soon enough
#6 |
expectation
| Freebird + Gainclone = "integrated" gainclone? | bikehorn | Chip Amps | 9 | 5th January 2006 03:07 PM |
| JLH v Gainclone? | Jezz-the-Fezz | Solid State | 5 | 12th December 2005 12:08 PM |
| Big gainclone | steven344 | Chip Amps | 10 | 23rd November 2005 07:58 PM |
| Page generated in 0.08285 seconds (73.20% PHP - 26.80% MySQL) with 11 queries |
