Old 26th April 2004, 02:28 PM   #1
mgreene is offline mgreene  United States
Default Reduce Input Gain Question?
Got my battery powered NIGC running over the weekend. Quite impressed with the sound, (1mv and 11mv offset.)
However, I built it to use with an active pre and it is TOO LOUD. I have a TVC output on my pre (does not fully attenuate the signal) and 93dB speakers. I used the same values as on Peter's monoblock schema. Just a 220R input series resistor to + and a 22K to ground.
I read here that the feedback resistors set the gain. How much attenuation can I expect by increasing the 680R from (-) to 1K or more?
I did try different values on the input series resistor - I happened to have a 3.6K Caddock and I thought it may have sounded better overall (?) , but didn't reduce the gain much. Any caveats I should consider, e.g., ratios of the input resistors?
Mike
Old 26th April 2004, 03:48 PM   #2
sss is offline sss  Israel
sss's Avatar
Send a message via ICQ to sss
if u are using not inverted gc then:
take the value of the resistor connected between the output of the chip to the negative input and divide it by the value of the resistor connected between the negative input and ground
if u will show a schematic it will be much easier to explain
Old 26th April 2004, 03:58 PM   #3
Hi, Thanks for the reply.
I am using the schema here:
http://www.diyaudio.com/forums/showt...546#post265546
Old 26th April 2004, 04:08 PM   #4
sss's Avatar
thats better
so the gain of your amp is 22000/680 = ~ 32
u can increase the value of 680r or reduce the value of 22k
dont play with the other input resistors hough
Old 26th April 2004, 05:43 PM   #5
Thanks,
I get it now.
Mike
Old 26th April 2004, 06:07 PM   #6
Note that if you reduce the gain via feedback you
are also reducing the stability margin of the amplifier.
sreten.
Old 26th April 2004, 07:19 PM   #7
I am open to other suggestions - althought I hve found several references from those who have apparently used 1K and 22K in the feedback loop with no problems.
I was thinking of rigging up an 1 step "attenuator" like a 10K series resistor and a shunt resistor to halve the gain. Any suggestions on values to accomplish this?
Mike
Old 27th April 2004, 02:06 AM   #8
sss's Avatar
its better to lower the gain of an amp then to use input attenuator , lower gain = better performance , anyways imho changing the gain from 30 to 20 or 10 wount do nothing to stability
Old 27th April 2004, 10:48 AM   #9
In your opinion stability is not affected ?
Opinion doesn't come into it. Gain margin and phase margin do.
sreten.
Old 27th April 2004, 11:32 AM   #10
sss's Avatar
well i think if u'll change the gain to 20 or 10 there wount be any stability problems
Attenuating input gain on X amp? jeffjazz Pass Labs 3 7th June 2007 02:39 PM
How to reduce gain of this Tube Preamplifier ? ANALOG GUY Tubes / Valves 5 22nd September 2006 03:37 AM
Preamp question/ input gain boost 3-LockBox Class D 2 13th June 2006 03:23 AM
Reduce input noise YUTK Solid State 18 27th December 2005 12:04 PM
basic question : reduce amps supplied by powersupply fezz Solid State 0 26th March 2002 08:58 PM
Page generated in 0.10083 seconds (78.22% PHP - 21.78% MySQL) with 11 queries
