Old 24th April 2004, 02:30 PM   #1
karma is offline karma  Canada
karma's Avatar
Default lm3875t? or lm3875tf
im sure some one has talked about it but i cant find it witch one is better isolated or non im about to order samples.
thanks.........
Old 24th April 2004, 03:55 PM   #2
Peter Daniel's Avatar
Send a message via AIM to Peter Daniel
Although I've been using non-isolated version mostly, my recent experiments indicate that isolated version sounds smoother and less harsh. I would recommend isolated version and that's what I'm using from now.
Old 24th April 2004, 04:20 PM   #3
tiroth is offline tiroth  United States
You are also saving yourself a world of mounting concerns with the isolated.
Old 24th April 2004, 05:09 PM   #4
karma's Avatar
Default thanks
now that i got this case together i wana make it a gainclone instead
Old 30th April 2004, 04:58 PM   #5
karma's Avatar
Default wow that was fast
national is fast on the shiping i just ordered them
Old 30th April 2004, 05:03 PM   #6
jackinnj's Avatar
on the other hand, you need a much larger heat sink with the insulated version
Old 30th April 2004, 05:09 PM   #7
I wouldn't think so. The chip transfers less heat to the heatsing, when it's insulated
Old 30th April 2004, 05:11 PM   #8
karma's Avatar
i got a few to play around with so we shall see. there samples so
if i loose one o well. the heatzincs on my case are from a 200watt
amp so it should keep it cool
Old 30th April 2004, 05:14 PM   #9
The heatsinks on your amp are good for 6 channel surround amp.
Old 30th April 2004, 05:34 PM   #10
karma's Avatar
this is true
next one will be smaller
National LM3875T for sale. Hisatugo Swap Meet 5 24th October 2009 12:27 AM
Lm3886t / Lm3875t / Tda7293 effective_audio Swap Meet 0 13th November 2008 02:23 AM
2 x LM3875T on the same heatsink ?! thoronx Chip Amps 9 23rd June 2008 09:41 AM
LM3875T to be obsoleted jackinnj Chip Amps 12 27th June 2007 08:20 PM
Sound Quality of LM3875T cwteoh Chip Amps 29 8th May 2004 01:19 AM
Page generated in 0.09120 seconds (76.68% PHP - 23.32% MySQL) with 11 queries
