Old 27th April 2004, 07:31 AM   #11
Default Not in the datasheet
The feedback network is not in the datasheet.
Your circuit has a gain of 1 at DC and a gain of 20 or so beyond the pole frequency and I really haven't taken the trouble to figure out what it really does.
Since people have found the feedback loop of the gainclone is THE MOST IMPORTANT element required to accomplish great sound, you should first try what has been found to work well and then experiment afterwards. What works well is a good, precision resistor of 20k (for your design) soldered extremely closely between pins 3 and 8. No capacitors on pin 8 at all unless you have really bad DC offset and then you should seek advice first.
Read the huge history here or just follow what BrianGT has done. Copy as much of his schematic as you can.
-Robert
Old 27th April 2004, 09:56 AM   #12
li_gangyi's Avatar
I'll have to comment that the 3875 gives great bass...just make sure your source is not clipping...did you use a PC?? I had one that would produce a clipped signal if the eq is set too high for the bass frequencies...
Kids in the back seat cause accidents...Accidents in the back seat cause kids...
Old 27th April 2004, 06:42 PM   #13
GregGC is offline GregGC  Canada
Make R32 1meg and R6 100K. See how it's going to sound then.
/Greg
Old 27th April 2004, 07:10 PM   #14
lucpes is offline lucpes  Europe
Send a message via Yahoo to lucpes
What are you using for the 0.1uF caps? Change to mylar.
Old 27th April 2004, 07:22 PM   #15
runebivrin's Avatar
Send a message via MSN to runebivrin
I'd like to know how your power supply looks. In your schematic you have 100µF caps as rail decoupling. Is that all you have? If so, there's a fair chance that's the source of you problem. 100µF into 8 ohms is ~200Hz.
Rune
Do wizards use spell checkers?
Old 27th April 2004, 08:40 PM   #16
Default 10kuF
The first post indicates he has 10,000uF at the output of the PS. Shouldn't be his problem.
-Robert
Old 28th April 2004, 01:19 AM   #17
cwteoh is offline cwteoh  Malaysia
1) I am using 10,000uF caps for both rails but do not have the 100uF and 0.1uF caps at chip.
2) I started the circuit as shown in datasheet but later change to the circuit I posted here because of ringing problem. then I found that is the zobel network that solved the ringing problem and not the feedback loop. Anyway, both version of schematics did not give much bass at all.
3) Do I need to add in tone control to boost the bass? Or, this gc himself is capable to produce "ceiling-booming" bass?
4) I am using a tube preamp which use 5687 as driver tube. Will this caused problem on the bass?
Thanks.
C.W. Teoh
Old 28th April 2004, 08:30 AM   #18
runebivrin's Avatar
If there's a coupling capacitor on the output of your preamp, or if the output impedance is high, you may have a problem. The input impedance of your GC is 11 kOhm. That could be too low. Try multiplying the input resistors by 10.
Rune
Old 28th April 2004, 11:50 AM   #19
mAJORD is offline mAJORD  Australia
In response to your bass issue, IF youve setup the feedback/gain correctly so ITs freq range is say 20-20000 at -3db, than it should produce the correct level of bass from thos freqs. ... anything but would afaiak be classed as distortion, should replicate the input signal !
-ed i dont think i made my point quite clear there... I was trying to say you should not need any tone controls to achive correct bass, only to ytailor any fetish you have with 'extra' bass
Old 30th April 2004, 02:58 AM   #20
Thanks for the info. Allow me to have some times to modify the input impedance and feedback configuration.
Will post the result regarding my finding later. thanks.
C.W. Teoh
Best possible sound quality from +12 ATX PSU Arnop Chip Amps 3 6th April 2009 11:40 AM
Better Sound Quality LqDFx Car Audio 14 16th June 2006 04:49 PM
Quality Control differences = variations in sound quality? KT Class D 0 14th November 2004 06:51 AM
Sound quality,which is best? Richard.C Chip Amps 10 23rd August 2004 07:58 AM
TAD sound quality Kal Multi-Way 12 6th April 2004 06:16 PM
Copyright ©1999-2013 diyAudio
