Old 23rd April 2004, 06:37 AM   #1
Account Disabled
Send a message via MSN to da_madaxeman
Unhappy amp bridging eating fuses, but load seems ok
heyhey. im eli.
as theChris once said, "noone replies to my threads but i'll give it a try"
my hifi amp, 4 ohm stable (well 2.666 tested due to an accidental wiring... dont ask) keeps dropping fuses when i attempt to bridge subs over it. its a four channel amp, about 35w rms/ch @ 4 ohms. The subs i use (i have quite a collection of not - so - good subs which i dont use) are two Kenwood KFC-XW10DBs. sparing you too many details, they are each 4ohm subs with power levels out of any reach of my hifi amp. They are wired in series in a single sealed box (came with them). I want to wire the 8ohm box over two channels (spk.B outputs L and R.. unless anyone has a better suggestion...and yes, i switch the amp to mono first..) and i have tried this in numerous ways, each way deciding to drop a fuse. Also, the single way that worked if anything seemed lower power... the way that worked being bridging two left channels (spk. A + B) in either of two ways. I havn't drawn out the wiring diagrams I have tried yet but i will do so tonight. this may sound a little stupid but could someone please post a simple bridging diagram up just so I know im doing it right? cheers.
also, would I be wrong in saying that the load should be ok? an 8 ohm load over two channels................= 4 ohms/ch?
Eli
Old 23rd April 2004, 07:00 AM   #2
Electrons are yellow and more is better!
peranders's Avatar
If you bridge connect you will increase the current. It will be the double with the same load.
You must have 8 ohms at least, I'll suspect.
If the amp can handle 2 ohms perfectly you can use 4 ohms in bridge mode.
If the amp can handle 4 ohms (not less) perfectly you can use 8 ohms (but not less!) in bridge mode.
/Per-Anders (my first name) or P-A as my friends call me
Old 28th April 2004, 10:59 AM   #3
Account Disabled
cheers, that was very helpful.
if there is a 16 ohm load bridged over two channels (ie 8 ohms per channel) would the amp be giving power of twice the 8 ohm power of one channel?
Old 28th April 2004, 11:03 AM   #4
peranders's Avatar
Which a 16 ohms load (bridged) each amp will "feel" 8 ohms load.
To answer your question, not twice but 150-180% (guess)... as long as you not exceed the current limits (may occur if you have too heavy load).
Why is my gainclone eating fuses? AJ Bertelson Chip Amps 16 12th February 2012 10:27 AM
Dynamic load line analysis using music and speaker load Michael Koster Tubes / Valves 0 7th March 2008 08:47 PM
Mono Bridging Carver Amp Into 4 ohm Load DreadPirate Solid State 28 24th January 2007 06:44 AM
Sub Amplifier talk: wattage, bridging, load, etc... LONG curtis73 Car Audio 5 14th December 2003 12:49 AM
Quad II eating valves? Zombie Tubes / Valves 31 26th February 2003 05:29 PM
Page generated in 0.08247 seconds (72.30% PHP - 27.70% MySQL) with 10 queries
