| Chip Amps Amplifiers based on integrated circuits |
Has anybody any idea why my lm1875 gainclone lack the speed compared to the tda7375? Could it be the 2x12vac 120va trafo and 8x byv28 sharing for both channel? The sound is indeed quite good but the music tend to slow down. I follow exactly Brian Gt lm3875 based gainclonce components value on my lm1875 gainclone. Is it ok to apply the value to lm1875?
Toni. |
#2 |
Electrons are yellow and more is better!
It can be something about available power. You maybe need a more powerful amp with more current and more speaker control?
/Per-Anders (my first name) or P-A as my friends call me |
#3 |
Thanks Peranders,
may be I should upgrade the trafo with higher rating like 2x18 300va perhaps? Toni. |
#4 |
12 volt per rail is tethering on the edge~!! I suppose you mean 12VAC...yeah might wanna go higher something in the region of 18-22VAC will do pretty well for you...I use a 22V dual trafo with 4.5A of current...seems to work well for 2 channels...
Kids in the back seat cause accidents...Accidents in the back seat cause kids... |
#5 |
Thanks anyway. I stop listening to the lm1875. Back to the tda7375 which had more speed. I'll try with bigger trafo the next time. Maybe it should solve the problem.
Toni. |
#6 |
I'v been using a lm1875 for a while and haven't nocticed any problems like that, and im running 8 channels on a 12V 3A transformer. Althogh I never turn them up high enogh to max the transformer.
#7 |
Oops..! Then what might had gone wrong with mine? Maybe the component value being used thru out, I follow exactly the value use for lm3875 by Brian GT and Peter Daniel. What about BYV28, are these good for GAINCLONE?
TONI |
#8 |
i'm building am amp using the lm1875, and wanted to know which pcb to use. The National datasheet gives two pcb's one for plit supply and one for single, what does single and split mean, and which one do i use for 5 channels?
thanks |
#9 |
single supply applications require only one side of a supply...BUT u have to use at least 12V if u're aiming for +/-12V originally...split supply means u use a centre tap rafo or a dual sec trafo and produce +/- voltages...a spilt supply system will require slightly less parts...
#10 |
Thank you very much li_gangyi, that really makes sense and i can't beleive that i did not figure it out myself. Thanks for the help now it's time to go make some pcb's. I'd like to post some pics of thm when they are finished.
| LM1875 nested Gainclone | linuxguru | Chip Amps | 90 | 15th March 2010 06:24 AM |
| Gainclone troulbe (LM1875 distorsion issue) | haft | Chip Amps | 10 | 25th February 2007 09:29 PM |
| My LM1875 gainclone... point2point... | w00t | Chip Amps | 21 | 23rd March 2005 10:12 AM |
| 2 general gainclone questions, and an lm1875 question | Adam M. | Chip Amps | 11 | 4th March 2005 12:53 PM |
| Just fired up my new dual mono lm1875 Gainclone. | Shoog | Chip Amps | 5 | 19th January 2004 07:09 PM |
| Page generated in 0.18635 seconds (57.11% PHP - 42.89% MySQL) with 11 queries |
