Old 21st April 2004, 02:13 PM   #1
mAJORD is offline mAJORD  Australia
Default LM3875, minimum input sensitivity (gainclone)
Hi peeps
I was wondering, if it would be possible to design an LM3875 gainclone amp with an input senstivity of line level.. in my case aiming for say 150mv/150k for a 40 watt output. into 8o , allowing me to hook a CD player straight up to it,
I would use Rin as the volume pot of course, as per NS typ applicaton schematic
If this is possible, can anyone think of major disadvantages?
the reason i ask this in the first place is, A. if i can avoid using a preamp in front of it i will , as im trying to make a very compact system. and B. i cant find any simple line level- typical 0.8v amp level preamp designs on the net that take my fancy.. nor find any decent pre-designed stereo preamp pcb kits ( so i dont have to make a PCB) , they seem to not exist, except in very complex form with bass treble balance controls etc , which i dont need!
so that leads me to a bit of a side question.. if i DO need a preamp, can anyone point me in the direction to a VERY simple but effective preamp to bring that level up to what ill need. ,
thanks in advance!.
Jimmy
Old 21st April 2004, 08:09 PM   #2
BlackDog's Avatar
Just use a volume pot. That's what most people do.
You don't need an active preamp at all.
Steve
Old 21st April 2004, 11:48 PM   #3
S.C is offline S.C  United States
Send a message via ICQ to S.C Send a message via AIM to S.C
for the pre amp problem, you should go to Solid State, or search here for some simple design.
Old 22nd April 2004, 02:07 AM   #4
garbage is offline garbage  Singapore
garbage's Avatar
you might want to check out DACT site for a preamp kit.
Old 22nd April 2004, 06:42 AM   #5
Electrons are yellow and more is better!
peranders's Avatar
You can decrease the gain to 10 and increase it up to 300 (with bandwidth of 20 kHz). If you increase the gain you may experience problems with too high output offest voltages.
/Per-Anders (my first name) or P-A as my friends call me
Minimum Internal Chassis Size For Audio Sector LM3875 Kit CarlosT Chip Amps 4 8th November 2006 03:11 AM
What is input sensitivity? boxedin Solid State 15 29th December 2005 09:04 PM
What’s the minimum power transformer required to build a gainclone amplifier? Katapum Chip Amps 23 4th December 2005 10:47 AM
minimum heatsink size for lm3875 mateo88 Chip Amps 2 7th June 2004 06:30 PM
LM3875 Newbie Question re: sensitivity Gringrath Chip Amps 3 12th January 2004 02:05 PM
Page generated in 0.08196 seconds (76.01% PHP - 23.99% MySQL) with 10 queries
