| Chip Amps Amplifiers based on integrated circuits |
I wanted to share this idea about a diy volume attenuator and sollicit ideas in the construction area and the connections.
#2 |
Some of the advantages I can think of:
+ Easy soldering + Slim (potentially fairly flat) so it can be placed in small enclosures + Only a single resistor in the signal path + As many resistance values as you want (with the cost of bigger area, but you can put on on top or bottom, so it can be made pretty big). It sorta reminds me of older pots/switches on 20's equipment. |
#3 |
Connections from the resitors to the anchor thingy might be like this:
#4 |
the switch you posted is not appropriate for volume, as it is non shorting type (make after break).
Although it looks very nice. |
#5 |
The switch in the picture is just for the connection mechanism inspiration. As far as a shorting version, or a stereo version, they are still be figured out. I want to keep construction as simple as possible.
#6 | |
se |
#7 |
Sorry I don't know the manufacturer. That's a rotary switch from the 30's. They were used in one-tube radios. the problem with these was that it was easy to accidententally touch the exposed brass.
#8 | |
Do you have just the one? I'd like to buy one or two if you have any to sell. se |
#9 |
Steve,
Going to hang a transformer on it...................... Regards, Jam |
#10 | |
se |
| diy stepped attenuator under 10$ | kaushik | Parts | 23 | 12th January 2012 11:37 AM |
| how is the quality of a chip-based volume control VS normal stepped attenuator? | jarthel | Parts | 4 | 16th July 2007 03:40 PM |
| stepped attenuator | ivegotmono | Tubes / Valves | 4 | 7th January 2006 03:49 PM |
| Volume Control via logrithmic stepped attenuator | PaulHilgeman | Solid State | 4 | 6th February 2003 12:51 PM |
| Gainclome Volume Control using Log Stepped Attenuator | PaulHilgeman | Parts | 10 | 5th February 2003 09:40 PM |
| Page generated in 0.09921 seconds (84.34% PHP - 15.66% MySQL) with 11 queries |
