Old 17th April 2004, 06:29 PM   #1
Send a message via ICQ to electro samurai
Default help! impedance!
can someone plz tell me what is this circuit's impedance?
Old 17th April 2004, 06:46 PM   #2
Frank Berry's Avatar
The LM1876 can drive either a 4 or an 8 ohm load.
Frank
Old 17th April 2004, 07:00 PM   #3
Default help
oh, oops...i ment input impedance
Old 17th April 2004, 07:05 PM   #4
I don't find any information about input impedance.
It's high.
What are you planning? Why is imput impedance important?
Frank
Old 17th April 2004, 07:28 PM   #5
djk is offline djk
djk's Avatar
If you read the manufacturers data sheet on this part you will find:
http://www.national.com/ds/LM/LM1876.pdf
You are missing a whole bunch of parts to make it work right.
The input resistor is suggested to be 47K
The zobel is 4R7 + 0.1µF
The damped coil for driving capacitive loads is 0.7µH + 10R
Old 17th April 2004, 08:47 PM   #6
"If you read the manufacturers data sheet on this part you will find:"
His attachment came from the manufacturers data sheet.
As I asked in my earlier post, what are you planning? Why is input impedance important?
Frank
Old 17th April 2004, 10:45 PM   #7
GregGC is offline GregGC  Canada
The imput impedance will depend on the resistor you put to GND from +in. You need it in order to provide a Ibias for +in. It can be from 1k or less to 1meg if you want but most likely from 20k to 200k (the circuit you have in the zip file has no DC gain). The best way is to determine what kind of Rin you need and than connect a resistor with that value there. If you're going to use a pot and no input cap than the input impedance will be determined by the pot.
Hope it helps.
/Greg
Old 18th April 2004, 10:40 AM   #8
djk is offline djk
djk's Avatar
"His attachment came from the manufacturers data sheet."
The data sheet runs to ~20 pages. The drawing he linked to is CONCEPTUAL, meaning it WON'T WORK properly without additional parts.
If you would bother to read the drawing marked 'typical audio circuit' you will see that it has more parts.
Not only that, but there is an explanation of what each part is/does.
If you can be bothered to read the WHOLE data sheet.
Old 18th April 2004, 12:35 PM   #9
It's high.
a guitar amp.
i think guitars have 1M impedance.
[i]Originally posted by djk
oh...i kind of copied the 'typical audio circuit'...so i think u might find them v-e-r-y similar.
about the in+ to gnd resistor, ive seen a guy who built this, with no such resistor, he claims it sound great.
i renewed it.
what do u think?
Old 18th April 2004, 01:12 PM   #10
HDTVman is offline HDTVman  United States
Try looking at the "Auxiliary Amplifier Application" This gives a more complete schematic. Read the ENTIRE APP. NOTE if you want to know what the manufacturer recomends. You will find the answer if you look for it.
Later BZ
What ever makes the tunes flow
What impedance? jaya000 Multi-Way 11 21st November 2008 07:04 AM
Impedance rate VS impedance stability TomatoBangBang Tubes / Valves 6 4th September 2008 10:46 PM
Hi Vi SD1.1 impedance guitarded Multi-Way 0 3rd February 2008 08:35 AM
Impedance and SPL.. TroelsM Multi-Way 5 26th September 2005 12:52 PM
Need help understanding transformer impedance ratios and impedance matching percy Tubes / Valves 5 28th February 2005 08:35 PM
Page generated in 0.12466 seconds (74.68% PHP - 25.32% MySQL) with 11 queries
