My_Ref problem: DC on output
Old 23rd June 2018, 11:01 PM   #1
erocfx is offline erocfx  United States
Default My_Ref problem: DC on output
I was testing a VU meter circuit on my working My_ref rev C amp.
Now I have -29 volts on my outputs and inputs. This is with the LM318 in or out of the circuit. I don't see any burned components, and it happened to both my channels. The +-12 volt is working.
Anyone have any ideas what to check, or what causes this?
Thanks,
Eroc
Old 24th June 2018, 02:23 AM   #2
Mark Whitney is offline Mark Whitney  Netherlands
Mark Whitney's Avatar
Unplug everything and check the resistance of the 1 Ohm resistors. It is R11 if I remember correctly.
Regards Mark.
Old 24th June 2018, 04:10 PM   #3
Good call Mark, R11 was open on both of them. I will replace those and see what happens. Thanks.
Old 24th June 2018, 05:07 PM   #4
If you want to prevent this from happening again add two back to back diodes across R11.
Regards Mark.
Old 24th June 2018, 05:46 PM   #5
Do you have a schematic for that? Any suggestion for which diodes?
Old 27th June 2018, 01:39 PM   #6
Are those in series or parallel with R11?
Old 27th June 2018, 08:49 PM   #7
Like this.
You could use 1N4001 or similar. Just need adequate surge overload rating.
Regards Mark.
Old 30th June 2018, 03:51 PM   #8
Thanks again for the help Mark!
Old 6th July 2018, 11:28 PM   #9
tomchr is offline tomchr  Canada
tomchr's Avatar
If you had enough current flowing in R11 to fry it, a pair of diodes won't help. They'll prevent the resistor from frying, but that'll likely just cause something else to fry. There isn't supposed to be any current running in R11, so I'd figure out where that current is coming from first.
Tom
Modulus-686: 240W/8Ω @ <0.00025% THD. Modulus-86: 40W/8Ω @ 0.000054% THD. DG300B & Other Tube Circuits.
Neurochrome : : Audio - www.neurochrome.com - Engineering : : Done : : Right
Old 7th July 2018, 06:10 AM   #10
Normally it is only R11 that has blown. My guess is that a high enough potential between the grounds when you plug in or switch on the amp is the cause.
Regards Mark.
My_Ref problem: DC on outputHide this!Advertise here!
My_Ref FE Peterma Swap Meet 1 22nd March 2018 10:08 PM
FS: PCB's (My_Ref & DCB1) maximm07 Swap Meet 4 4th June 2014 06:11 AM
FS : My_Ref FE Premium BoM pinnocchio Swap Meet 11 8th November 2013 06:06 PM
My_Ref RevO ClaveFremen Chip Amps 52 22nd September 2011 06:07 PM
WTB My_Ref Rev C nvrgdenuf Swap Meet 2 29th January 2010 07:37 PM
