Best value for Rmute ? ......... + & - 36VDC rails ......
Old 23rd June 2018, 12:27 AM   #1
hitsware is offline hitsware
Default Best value for Rmute ? ......... + & - 36VDC rails ......
Old 23rd June 2018, 12:59 AM   #2
Clueless but avid is offline Clueless but avid  Germany
This is pretty complete for the LM3886 >
A Complete Guide to Design and Build a Hi-Fi LM3886 Amplifier - Circuit Basics
Old 27th June 2018, 09:12 AM   #3
tomchr is offline tomchr  Canada
tomchr's Avatar
As mentioned in the LM3886 data sheet, the LM3886 needs 500 uA through the MUTE pin to fully un-mute. Thus, ensure that the MUTE current doesn't droop below 500 uA at the worst case supply voltage (including ripple voltage).
There's about 3 V across the MUTE circuit in the LM3886, so following Ohm's Law, you can work out the needed resistance:
RMUTE_max = (Vsupply_min - 3)/0.0005
I'd round down to the nearest lower E-12 value for RMUTE.
Tom
Modulus-686: 240W/8Ω @ <0.00025% THD. Modulus-86: 40W/8Ω @ 0.000054% THD. DG300B & Other Tube Circuits.
Neurochrome : : Audio - www.neurochrome.com - Engineering : : Done : : Right
Best value for Rmute ? ......... + &amp; - 36VDC rails ......Hide this!Advertise here!
50+50 v rails east electronics Solid State 32 25th February 2014 04:19 PM
Benefits/Drawbacks of Dual rails vs Single Rails buzzforb Pass Labs 2 25th May 2011 01:06 PM
25vdc compared to 36vdc on 7294, looking for input on design trigger Solid State 1 3rd March 2011 12:29 PM
P3A on +/-12V rails 00940 Solid State 6 5th March 2008 12:44 PM
15V from 25VAC/36VDC jimbo1968 Power Supplies 6 18th July 2006 07:21 AM
