Old 17th April 2004, 04:41 AM   #1
Default Phonocube
HI,
Has anyone cloned the 47labs Phonocube?
BIG POPA
Old 19th April 2004, 07:27 PM   #2
platenspeler's Avatar
Default first try
A while ago I started building a preamp that would fit the limited descriptions of Phonocube. Unfortunately I did not find much info on the Phonocube on the web other than hints suggesting an inverted design.
I recently finished following pre-amp, which is small enough to fit in a Phonocube enclosure, and contains a minimum of components.
It's still a proto but sound is OK and I'm finishing the housing (which has room for battery power supply) right now.
Maarten
see http://www.platenspeler.com diy section for more info
Old 19th April 2004, 08:06 PM   #3
And the schema, it's MC only ...
phonocube power in wet weasel Analogue Source 0 10th November 2007 06:59 AM
Page generated in 0.06980 seconds (67.50% PHP - 32.50% MySQL) with 11 queries
