A query on the output level of the Preamplifier 2012 (Elektor April, May & June 2012) & input level on the Elektor Q-Watt Power Amp (Elektor September 2013).
As there appears to be quite a high level output from the Preamplifier 2012, if it's connected to the Q-Watt then there appears to be a 'mismatch' of levels.
Can something be done to keep them in line, otherwise i fear with the Preamplifiers volume turned up to a high level it could over-drive the Q-Watt?
Knob
What do you expect a knob to do?
Perhaps it depends on the colour of the knob!
Use the Volume knob. That's what it is for.
Pot?
What value would we be talking about?
Impedance matching?
So how should the pot be wired?Or do not use preamp at all. Just a pot infront of the amp.
Impedance matching?
