Old 16th April 2004, 01:13 AM   #1
Send a message via ICQ to rampage101 Send a message via MSN to rampage101
Default Pics of my first gainclone!!
Its pretty much all done, just need to finish putting it in the case, then fix the volume control. I need a 20k pot I think, I used the NIGC design in BrianGT's PDF.
What's a signiture?
Old 16th April 2004, 02:06 AM   #2
looks good,
im sure you know but if the case is metal you need the TF version of the chip, not the T version to prevent the voltage on the die of the chip from comming in contact with the case and shorting it to V-.
Old 16th April 2004, 02:18 AM   #3
Yep. I've got 5 of the TF samples coming, but if I can get the insulator pads and screws then I can just use the setup I have.
What's a signiture?
Old 16th April 2004, 03:17 AM   #4
I agree, well done.
If your going to mount it into a box, you may want to get better speaker terminals (say bananas) instead of the spring-clip type.
The only other thing, hope its fused at that IEC socket of yours.
Thats about it from me, I'll shut up now
Old 16th April 2004, 04:30 AM   #5
Fuse? Did someone say fuse?
/me hides shamefully in the corner
Yes, I gotta get some fuses for it. Would 1.5A slo-blow be sufficient for the AC Hot in line, like directly after the IEC socket?
What's a signiture?
Old 16th April 2004, 07:04 AM   #6
Depends what size toroid your using.
Anyway, the toroid usually suggests a certain inline fuse value.
Hope that helps....
Old 21st April 2004, 02:13 AM   #7
Well, after i got home from my parents house after fully bolting everything into a case, I tried to test my amp. Well, arn't I intelligent in thinking the bolts holding the heatsinks to the will be fine. I forgot to insulate them. So I killed my chips, and have since been waiting for my 5 TF samples.
They arrived! Hopefully withing the next 4 hours I can have it setup and working again.
What's a signiture?
Old 21st April 2004, 04:00 AM   #8
Use thermal insulating pads between the chips and heatsink. Cos at the moment, it looks like your heatsink will have a -35V voltage on it due to the screw holding it to the heatsink.
And while your at it, when I built mine, I made clamps for the chips, rather than bolting them through the screw hole. That way, it'll avoid the screw from passing current onto the heatsink.
The best thermal insulating pads out there I reckon is the thermagon stuff. Fairly expensive though.
www.thermagon.com
Old 21st April 2004, 05:24 AM   #9
How did you make that PCB??? Is there any copper on it? Did you just drill the holes?
Also, do you happen to have a link to that PDF of BrianGTs?
Looking good
Old 21st April 2004, 05:29 AM   #10
S.C is offline S.C  United States
Send a message via ICQ to S.C Send a message via AIM to S.C
I think that is basically point to point soldering with a "board" to hold it in place.
My first Gainclone almost done (pics!) maxw Chip Amps 27 29th March 2005 11:14 AM
pics of my gainclone saabie22 Chip Amps 4 14th June 2004 06:39 PM
Pics of my first gainclone red Chip Amps 2 23rd March 2004 08:46 PM
PICS: GainClone Monoblock pics Rarkov Chip Amps 19 17th April 2003 07:37 AM
Page generated in 0.10669 seconds (75.14% PHP - 24.86% MySQL) with 10 queries
