| Chip Amps Amplifiers based on integrated circuits |
I'm a newb but here are some of the construction techniques I used.
I built the interconnects directly into the amp boards. The interconnects are three braided pairs of UTP and then split out to solids & stripes. They go to Dayton solder type gold plate connectors. They are covered with the braided shield from some old IBM twinax then finished with shrink. I also used the twinax shield for the 110V to the front DPST switch. Binding posts (Dayton gold stuff,again) are soldered. The front and rear panels are from 1" aluminum plate laying around. The rear billet was milled to be an integral heat sink. I think that it provides only adequate heat dissipation. The binding posts are mounted in an insulating nylon block. Cabinet sides are walnut, base is MDF. The front panel is attached to the walnut sides by 10/32 epoxied thread inserts. The lid is 1/8" aluminum tread plate. I am powering some line arrays that I built last month (http://www.diyaudio.com/forums/showt...532#post368532). The sound is very, very clean. Crisp. Absolutely no hum or buzz. The amp runs a little warm at high volumes but the nominal impedance of the speakers is only ~4.2 ohms. I will avoid any comparisons to my current Adcoms other than saying the only discernable difference is the 50WPC amp's bass is less than the 350WPC amp's bass. Duh? What would I do differently? I'll build the next one with a pot and avoid the whole preamp thing. I'll also build with larger heatsinks. I don't think that a pound of mass per chip (of proper finned heatsink) would be out of line for these. I'll also not confuse the resistors and have to desolder (and then work with 3mm leads!). The best part...I'm listening to my own stuff. Stuff that I built. Of course, knowing full well that it would not have been possible without the help of Meredith and that guy she's married to. I would also like to thank the diyaudio community, this stuff is very cool. |
#2 |
and...
#3 |
#4 |
#5 | |
Nice! Love the wood. And the diamond plate's a nice touch.
Good job! se |
#6 |
Nice work
#7 |
diyAudio Moderator Emeritus
Very nice! I like the milled panels!
-- Brian |
#8 |
With build quality like that, I wonder if you live in an earthquake zone
Very nice.
The truth need not be veiled, for it veils itself from the eyes of the ignorant. |
#9 |
I put the pictures in my gallery of finished gainclone projects using the pcbs that I made:
http://www.briangt.com/gallery/nigc -- Brian |
#10 |
Whoah! Now this is cool! Love the top plate!
| My Completed Krell KSA 50 Clone - Pics | lgreen | Solid State | 23 | 1st March 2012 06:44 AM |
| Milled from solid aluminum billet... | schodge | Parts | 14 | 11th March 2008 07:26 AM |
| pics of my diy-proj : clone krell-ksa100mkII | hukou | Solid State | 34 | 15th October 2006 10:56 AM |
| JM Lab Mini Utopia clone pics | SpeakerNut | Multi-Way | 0 | 16th February 2005 03:03 AM |
| JM Lab Utopia/Grande Hybrid clone pics | SpeakerNut | Multi-Way | 0 | 11th February 2005 02:57 AM |
| Page generated in 0.11467 seconds (70.23% PHP - 29.77% MySQL) with 11 queries |
